deepstream4.0 GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvstreammux",Why?
I try to install deepstream4.0 and test the sample.
my command like this:
deepstream-app -c samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
but I get error:
** ERROR: <create_multi_source_bin:653>: Failed to create element 'src_bin_muxer'
** ERROR: <create_multi_source_bin:715>: create_multi_source_bin failed
** ERROR: <create_pipeline:967>: create_pipeline failed
** ERROR: <main:632>: Failed to create pipeline
Quitting
so ,I use GST_DEBUG=3 deepstream-app -c samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt and got this:
0:00:00.016348189  4765 0x5574dfe86010 WARN     GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvstreammux"!
I try to delete the cache file.and get this :
rm ~/.cache/gstreamer-1.0/registry.x86_64.bin
tms@tms-Super-Server:~/software/deepstream_sdk_v4.0_x86_64$ gst-inspect-1.0 -b
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.481: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.481: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.481: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_of.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.481: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.481: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.483: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.483: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.483: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpegdec.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.483: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ofvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.483: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.484: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.484: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_segvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.484: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.484: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.707: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.708: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.708: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_of.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.708: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.709: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.709: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.709: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.710: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpegdec.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.710: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ofvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.710: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.711: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.711: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_segvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.712: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.712: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
文件黑名单:
  libnvdsgst_infer.so
  libnvdsgst_of.so
  libnvdsgst_osd.so
总数: 14 个黑名单文件
I got many alert info and 14 files in blacklist.but i can’t get nvstreammux.
and I notic alert info like this:
(gst-plugin-scanner:4773): GStreamer-WARNING **: 18:49:55.712: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so’: libcudart.so.10.1: cannot open shared object file: No such file or directory
but ,I have the file use this command:
$ls /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so
so,the file is ok,but why i can’t open with sudo?
gst-inspect-1.0 nvstreammux
没有那样的组件或插件‘nvstreammux’
my system is ubuntu 18.04 ,with cuda 10.0 and trt 5.1.5.0
so,why i got error?could u help me?
Hi tms2003,
Please check if your NVIDIA driver is the latest one, you could find relevant driver information from official website.
Be sure to reboot the system after installed.
/opt/nvidia/deepstream/deepstream-4.0/sources/objectDetector_Yolo$ gst-inspect-1.0 nvstreammux
0:00:00.002649831  7205 0x55b4af7ca630 WARN            GST_REGISTRY gstregistrybinary.c:490:gst_registry_binary_check_magic: Binary registry magic version is different : 1.3.0 != 1.12.0
0:00:00.738340451  7206 0x560a48600e10 WARN                 default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x120000: 'AVR (Audio Visual Research)' is not mapped
0:00:00.738395067  7206 0x560a48600e10 WARN                 default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x180000: 'CAF (Apple Core Audio File)' is not mapped
0:00:00.738408738  7206 0x560a48600e10 WARN                 default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x100000: 'HTK (HMM Tool Kit)' is not mapped
0:00:00.738420471  7206 0x560a48600e10 WARN                 default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xc0000: 'MAT4 (GNU Octave 2.0 / Matlab 4.2)' is not mapped
0:00:00.738433690  7206 0x560a48600e10 WARN                 default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xd0000: 'MAT5 (GNU Octave 2.1 / Matlab 5.0)' is not mapped
0:00:00.738444479  7206 0x560a48600e10 WARN                 default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x210000: 'MPC (Akai MPC 2k)' is not mapped
0:00:00.738457431  7206 0x560a48600e10 WARN                 default gstsf.c:98:gst_sf_create_audio_template_caps: format 0xe0000: 'PVF (Portable Voice Format)' is not mapped
0:00:00.738470701  7206 0x560a48600e10 WARN                 default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x160000: 'SD2 (Sound Designer II)' is not mapped
0:00:00.738486704  7206 0x560a48600e10 WARN                 default gstsf.c:98:gst_sf_create_audio_template_caps: format 0x190000: 'WVE (Psion Series 3)' is not mapped
0:00:00.765344152  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstflv.so: undefined symbol: gst_aggregator_pad_has_buffer
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:04.695: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstflv.so': /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstflv.so: undefined symbol: gst_aggregator_pad_has_buffer
0:00:01.641273565  7206 0x560a48600e10 WARN                  ladspa gstladspa.c:507:plugin_init:<plugin155> no LADSPA plugins found, check LADSPA_PATH
0:00:01.643706007  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstcoreelements.so: undefined symbol: gst_type_find_helper_get_range_full
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.574: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstcoreelements.so': /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstcoreelements.so: undefined symbol: gst_type_find_helper_get_range_full
0:00:01.652843096  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopengl.so: undefined symbol: gst_egl_image_from_texture
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.583: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopengl.so': /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopengl.so: undefined symbol: gst_egl_image_from_texture
0:00:01.670260050  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.600: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.670508830  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.601: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.670709610  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.601: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.671284022  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.601: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.672109096  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.602: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.672380792  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.602: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.672584980  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.603: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.672777517  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.603: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_segvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.673021926  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.603: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpegdec.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.673223914  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.603: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.673426902  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.604: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.673618907  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.604: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ofvisual.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.673818924  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.604: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.674009210  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libcudart.so.10.1: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.604: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_of.so': libcudart.so.10.1: cannot open shared object file: No such file or directory
0:00:01.901320509  7206 0x560a48600e10 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstgtk.so: undefined symbol: gst_gl_display_wayland_new_with_display
(gst-plugin-scanner:7206): GStreamer-WARNING **: 02:37:05.831: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstgtk.so': /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstgtk.so: undefined symbol: gst_gl_display_wayland_new_with_display
No such element or plugin 'nvstreammux'
$ nvidia-smi
Wed Aug 21 02:38:10 2019
| NVIDIA-SMI 430.40       Driver Version: 430.40       CUDA Version: 10.1     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 1080    Off  | 00000000:01:00.0  On |                  N/A |
| 34%   52C    P0    37W / 180W |   1403MiB /  8118MiB |      0%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0      1409      G   /usr/lib/xorg/Xorg                           490MiB |
|    0      1644      G   /usr/bin/gnome-shell                         334MiB |
|    0      9914      G   ...quest-channel-token=6768318621729276611   576MiB |
$ nvcc --version
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Mon_Mar_11_22:07:30_CDT_2019
Cuda compilation tools, release 10.0, V10.0.326
I still confuse about which CUDA_VER should I use. I think 10.0, but at nvidia-smi says: 10.1.
All program I compile with CUDA_VER=10.0.
Thank you very much.
Warmest regards,
Suryadi
HI Suryadi,
For you issue, please file a new topic with your issue, and platform, system environment information as reference.
For this experiment, I try on ubuntu 18.04, x86_64. Thanks.
Did you fix this problem??
