DeepStream SDK 4.0
Ubuntu 16.04
Server with T4 and P4 GPU’s
hi all, I am running deepstream-app from local host and getting these errors:
user@localhost:~/deepstream_sdk_v4.0_x86_64/sources/apps/sample_apps/deepstream-app$ sudo GST_DEBUG=4 deepstream-app -c /home/deepstream_sdk_v4.0_x86_64/samples/configs/deepstream-app/source30resnet_tiled_display_int8.txt
0:00:00.000052489 79935 0x55b7a32e2c00 INFO GST_INIT gst.c:511:init_pre: Initializing GStreamer Core Library version 1.8.3
0:00:00.000115918 79935 0x55b7a32e2c00 INFO GST_INIT gst.c:512:init_pre: Using library installed in /usr/lib/x86_64-linux-gnu
0:00:00.000132018 79935 0x55b7a32e2c00 INFO GST_INIT gst.c:523:init_pre: Linux r7425-p4 4.4.0-133-generic #159-Ubuntu SMP Fri Aug 10 07:31:43 UTC 2018 x86_64
0:00:00.000401284 79935 0x55b7a32e2c00 INFO GST_INIT gstmessage.c:119:_priv_gst_message_initialize: init messages
0:00:00.000786668 79935 0x55b7a32e2c00 INFO GST_INIT gstcontext.c:83:_priv_gst_context_initialize: init contexts
0:00:00.000929697 79935 0x55b7a32e2c00 INFO GST_PLUGIN_LOADING gstplugin.c:316:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.001006401 79935 0x55b7a32e2c00 INFO GST_PLUGIN_LOADING gstplugin.c:224:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.001016900 79935 0x55b7a32e2c00 INFO GST_PLUGIN_LOADING gstplugin.c:226:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.001039202 79935 0x55b7a32e2c00 INFO GST_REGISTRY gstregistry.c:1723:ensure_current_registry: reading registry cache: /home/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.013302227 79935 0x55b7a32e2c00 INFO GST_REGISTRY gstregistrybinary.c:619:priv_gst_registry_binary_read_cache: loaded /home/.cache/gstreamer-1.0/registry.x86_64.bin in 0.012
0:00:00.013347613 79935 0x55b7a32e2c00 INFO GST_REGISTRY gstregistry.c:1579:scan_and_update_registry: Validating plugins from registry cache: /home/.cache/gstreamer-1.0/registry.x8
0:00:00.014508313 79935 0x55b7a32e2c00 INFO GST_REGISTRY gstregistry.c:1681:scan_and_update_registry: Registry cache has not changed
0:00:00.014519344 79935 0x55b7a32e2c00 INFO GST_REGISTRY gstregistry.c:1758:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.014527178 79935 0x55b7a32e2c00 INFO GST_INIT gst.c:724:init_post: GLib runtime version: 2.48.2
0:00:00.014535324 79935 0x55b7a32e2c00 INFO GST_INIT gst.c:726:init_post: GLib headers version: 2.48.1
0:00:00.014542467 79935 0x55b7a32e2c00 INFO GST_INIT gst.c:727:init_post: initialized GStreamer successfully
0:00:00.014824136 79935 0x55b7a32e2c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element "pipeline" named "pipeline"
0:00:00.014913364 79935 0x55b7a32e2c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create: creating element "bin" named "multi_src_bin"
0:00:00.014934784 79935 0x55b7a32e2c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:457:gst_element_factory_make: no such element factory "nvstreammux"!
** ERROR: <create_multi_source_bin:653>: Failed to create element 'src_bin_muxer'
** ERROR: <create_multi_source_bin:715>: create_multi_source_bin failed
** ERROR: <create_pipeline:967>: create_pipeline failed
** ERROR: <main:632>: Failed to create pipeline
Quitting
