Hi
I am using objectDetector_Yolo with two custom model.
I successfully changed config file to use one model.
I want to know how to add one more model for inference.
I see that deepstream_app_config_yoloV3.txt has [primary-gie]. What should be added to use one more model?
Thank you.
I checked https://docs.nvidia.com/metropolis/deepstream/4.0/Custom_YOLO_Model_in_the_DeepStream_YOLO_App.pdf and in step 3 I need to change the kANCHORS.
If the kANCHORS is different for the two models, how should I set it?
mchi
August 26, 2020, 3:44am
4
Hi @pijebom737 ,
Sorry for delay! the 2nd model is not YoloV3, right?
You could refer to deepstream-test2, replace the first model with YoloV3 and the sgie1 model to your model, and remove other sgie models.
Do you mean the 2nd model also use kANCHORS ?
mchi
September 1, 2020, 4:34am
7
@PhongTN ,
Refer to the YoloV3 config file and the code the deepstream-test2.
