Dear All,
Can someone help me with creating config for using tensorflowf flow graph in
deepstream_sdk_on_jetson/sources/apps/sample_apps/deepstream-test1 test app.
Current dstest1_pgie_config.txt file is for caffe.
Thanks in advance.
Dear All,
Thanks in advance.
This includes two steps:
1. Please convert your tensorflow model into uff file first.
https://github.com/NVIDIA-AI-IOT/tf_to_trt_image_classification/blob/master/scripts/convert_plan.py#L18
2. Run deepstream with the converted .uff model:
You can find a sample config in ${deepstream_sdk_on_jetson}/sources/objectDetector_SSD.
Hi AastaLLL,
Step 1. I see that I need to use this command
python scripts/convert_plan.py data/frozen_graphs/inception_v1.pb data/plans/inception_v1.plan input 224 224 InceptionV1/Logits/SpatialSqueeze 1 0 float
I am confused about output node names. In my application, I use https://github.com/tensorflow/models/tree/master/research/object_detection
I use multiple output names.
How will this work there?
Sorry for the late reply.
You can mark multiple output layer as a list. Like:
uff_model = uff.from_tensorflow_frozen_model(
frozen_file=frozen_graph_filename,
output_nodes=[output_name1,output_name2,...],
output_filename=TMP_UFF_FILENAME,
text=False,
