**• Hardware Platform (Jetson / GPU) GPU
**• DeepStream Version 5.0
**• JetPack Version (valid for Jetson only) None
**• TensorRT Version Same as deepstream 5.0 devel docker
**• NVIDIA GPU Driver Version (valid for GPU only) Same as deepstream 5.0 devel docker
Firstly, I run SSD example to Deepstream successfully in opt\nvidia\deepstream\deepstream-5.0\sources\objectDetector_SSD with ssd_inception_v2_coco_2017_11_17.tar.gz (91 class COCO). Then I want to retrain the model with my custom dataset (2 classes). I use Tensorflow Object Detection API (GitHub - tensorflow/models: Models and examples built with TensorFlow, version r1.13.0, TF 1.14). I retrain and export model successfully and get trained model.
My ssd_inception_v2_coco config
model {
ssd {
num_classes: 2
box_coder {
faster_rcnn_box_coder {
y_scale: 10.0
x_scale: 10.0
height_scale: 5.0
width_scale: 5.0
matcher {
argmax_matcher {
matched_threshold: 0.5
unmatched_threshold: 0.5
ignore_thresholds: false
negatives_lower_than_unmatched: true
force_match_for_each_row: true
similarity_calculator {
iou_similarity {
anchor_generator {
ssd_anchor_generator {
num_layers: 6
min_scale: 0.2
max_scale: 0.95
aspect_ratios: 1.0
aspect_ratios: 2.0
aspect_ratios: 0.5
aspect_ratios: 3.0
aspect_ratios: 0.3333
reduce_boxes_in_lowest_layer: true
image_resizer {
fixed_shape_resizer {
height: 300
width: 300
box_predictor {
convolutional_box_predictor {
min_depth: 0
max_depth: 0
num_layers_before_predictor: 0
use_dropout: true
dropout_keep_probability: 0.8
kernel_size: 3
box_code_size: 4
apply_sigmoid_to_scores: false
conv_hyperparams {
activation: RELU_6,
regularizer {
l2_regularizer {
weight: 0.001
initializer {
truncated_normal_initializer {
stddev: 0.03
mean: 0.0
feature_extractor {
type: ‘ssd_inception_v2’
min_depth: 16
depth_multiplier: 1.0
conv_hyperparams {
activation: RELU_6,
regularizer {
l2_regularizer {
weight: 0.001
initializer {
stddev: 0.03
mean: 0.0
batch_norm {
train: true,
scale: true,
center: true,
decay: 0.9997,
epsilon: 0.001,
override_base_feature_extractor_hyperparams: true
loss {
classification_loss {
weighted_sigmoid {
localization_loss {
weighted_smooth_l1 {
hard_example_miner {
num_hard_examples: 3000
iou_threshold: 0.99
loss_type: CLASSIFICATION
max_negatives_per_positive: 3
min_negatives_per_image: 0
classification_weight: 1.0
localization_weight: 1.0
normalize_loss_by_num_matches: true
post_processing {
batch_non_max_suppression {
score_threshold: 1e-8
iou_threshold: 0.6
max_detections_per_class: 100
max_total_detections: 100
score_converter: SIGMOID
}train_config: {
batch_size: 16
optimizer {
rms_prop_optimizer: {
learning_rate: {
exponential_decay_learning_rate {
initial_learning_rate: 0.004
decay_steps: 800720
decay_factor: 0.95
momentum_optimizer_value: 0.9
decay: 0.9
epsilon: 1.0
fine_tune_checkpoint: “/home/pham_t/Detection/models/research/pretrained_model/model.ckpt”
from_detection_checkpoint: trueNote: The below line limits the training process to 200K steps, which we
empirically found to be sufficient enough to train the pets dataset. This
effectively bypasses the learning rate schedule (the learning rate will
never decay). Remove the below line to train indefinitely.
num_steps: 2000
data_augmentation_options {
random_horizontal_flip {
ssd_random_crop {
}train_input_reader: {
tf_record_input_reader {
input_path: “/home/pham_t/Detection/data/train_labels.record”
label_map_path: “/home/pham_t/Detection/data/label_map.pbtxt”
}eval_config: {
num_examples: 1839Note: The below line limits the evaluation process to 10 evaluations.
Remove the below line to evaluate indefinitely.
max_evals: 10
}eval_input_reader: {
input_path: “/home/pham_t/Detection/data/test_labels.record”
shuffle: false
num_readers: 1
I inference successfully the trained model and get the good result in the custom dataset. So I want to adapt the trained model to Deepstream
I convert to uff model by python3 /usr/lib/python2.7/dist-packages/uff/bin/convert_to_uff.py frozen_inference_graph.pb -O NMS -p /usr/src/tensorrt/samples/sampleUffSSD/config.py -o model.uff
. I only change the num_classes =3 in /usr/src/tensorrt/samples/sampleUffSSD/config.py
import graphsurgeon as gs
import tensorflow as tfInput = gs.create_node(“Input”,
op=“Placeholder”,
dtype=tf.float32,
shape=[1, 3, 300, 300])
PriorBox = gs.create_plugin_node(name=“GridAnchor”, op=“GridAnchor_TRT”,
numLayers=6,
minSize=0.2,
maxSize=0.95,
aspectRatios=[1.0, 2.0, 0.5, 3.0, 0.33],
variance=[0.1,0.1,0.2,0.2],
featureMapShapes=[19, 10, 5, 3, 2, 1])
NMS = gs.create_plugin_node(name=“NMS”, op=“NMS_TRT”,
shareLocation=1,
varianceEncodedInTarget=0,
backgroundLabelId=0,
confidenceThreshold=1e-8,
nmsThreshold=0.6,
topK=100,
keepTopK=100,
numClasses=3,
inputOrder=[0, 2, 1],
confSigmoid=1,
isNormalized=1)
concat_priorbox = gs.create_node(name=“concat_priorbox”, op=“ConcatV2”, dtype=tf.float32, axis=2)
concat_box_loc = gs.create_plugin_node(“concat_box_loc”, op=“FlattenConcat_TRT”, dtype=tf.float32, axis=1, ignoreBatch=0)
concat_box_conf = gs.create_plugin_node(“concat_box_conf”, op=“FlattenConcat_TRT”, dtype=tf.float32, axis=1, ignoreBatch=0)namespace_plugin_map = {
“MultipleGridAnchorGenerator”: PriorBox,
“Postprocessor”: NMS,
“Preprocessor”: Input,
“ToFloat”: Input,
“image_tensor”: Input,
“MultipleGridAnchorGenerator/Concatenate”: concat_priorbox,
“MultipleGridAnchorGenerator/Identity”: concat_priorbox,
“concat”: concat_box_loc,
“concat_1”: concat_box_conf
}def preprocess(dynamic_graph):
# Now create a new graph by collapsing namespaces
dynamic_graph.collapse_namespaces(namespace_plugin_map)
# Remove the outputs, so we just have a single output node (NMS).
dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False
When I get the uff model, I adapt to Deepstream but I got the error:
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: Parameter check failed at: …/builder/Layers.h::setAxis::367, condition: axis >= 0
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: Concatenate/concat: all concat input tensors must have the same dimensions except on the concatenation axis (0), but dimensions mismatched at input 1 at index 1. Input 0 shape: [2,7668,1], Input 1 shape: [2,4332,1]
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: UffParser: Parser error: BoxPredictor_0/ClassPredictor/BiasAdd: The input to the Scale Layer is required to have a minimum of 3 dimensions.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:370 Failed to parse UFF file: /root/ssd_deepstream/model.uff, incorrect file or incorrect input/output blob names
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:971 failed to build network since parsing model errors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:872 failed to build network.
My infer_primary_ssd config
[pipeline]
height=720
width=1280
fd_height=360
fd_width=640
batch_size=1
framerate=30[property]
gpu-id=0
net-scale-factor=0.0039215697906911373onnx-file=models/model.onnx
model-engine-file=models/mm_ssd_b1_fp32.engine
labelfile-path=coco_ssd.txt
src_uri=file:///root/ssd_deepstream/video/gun.mp4
uff-file=model.uff
uff-input-dims=3;300;300;0
uff-input-blob-name=Input0=Group Rectangles, 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
cluster-mode=4
parse-bbox-func-name=NvDsInferParseCustomSSD
custom-lib-path=libs/libnvds_infermmparser.sobatch-size=1
process-mode=1
model-color-format=00=FP32, 1=INT8, 2=FP16 mode
network-mode=0
num-detected-classes=2
interval=0
gie-unique-id=1
output-blob-names=MarkOutput_0
The difference between my trained model and the original model is num_classes. Can anyone give me some recommendations to fix this error? Thanks!
