I have a SSD-Mobilenetv2 trained on my own custom dataset using tensorflow. I plan on converting it to UFF to be used by deepstream. The conversion seem to run fine while using the convert-to-uff.py file while throwing a few warnings. However while running the tensorrt code it throws an error.
This is the output of convert-to-uff.py command
god@jetson-nano:/usr/lib/python2.7/dist-packages/uff/bin$ python3 convert_to_uff.py --input-file /home/god/frozen_inference_graph.pb -O NMS -p /usr/src/tensorrt/samples/sampleUffSSD/config.py -t
2019-11-16 20:24:15.936610: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudart.so.10.0
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:516: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint8 = np.dtype([("qint8", np.int8, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:517: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint8 = np.dtype([("quint8", np.uint8, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:518: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint16 = np.dtype([("qint16", np.int16, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:519: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_quint16 = np.dtype([("quint16", np.uint16, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:520: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
_np_qint32 = np.dtype([("qint32", np.int32, 1)])
/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/dtypes.py:525: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
np_resource = np.dtype([("resource", np.ubyte, 1)])
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:541: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:542: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:543: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:544: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:545: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/usr/local/lib/python3.6/dist-packages/tensorboard/compat/tensorflow_stub/dtypes.py:550: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py:18: The name tf.GraphDef is deprecated. Please use tf.compat.v1.GraphDef instead.
Loading /home/god/frozen_inference_graph.pb
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py:231: The name tf.gfile.GFile is deprecated. Please use tf.io.gfile.GFile instead.
NOTE: UFF has been tested with TensorFlow 1.12.0. Other versions are not guaranteed to work
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/graphsurgeon/_utils.py:2: The name tf.NodeDef is deprecated. Please use tf.compat.v1.NodeDef instead.
WARNING: To create TensorRT plugin nodes, please use the `create_plugin_node` function instead.
UFF Version 0.6.3
=== Automatically deduced input nodes ===
[name: "Input"
op: "Placeholder"
attr {
key: "dtype"
value {
type: DT_FLOAT
attr {
key: "shape"
value {
shape {
dim {
dim {
dim {
dim {
Using output node NMS
Converting to UFF graph
Warning: No conversion function registered for layer: NMS_TRT yet.
Converting NMS as custom op: NMS_TRT
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:179: The name tf.AttrValue is deprecated. Please use tf.compat.v1.AttrValue instead.
Warning: No conversion function registered for layer: FlattenConcat_TRT yet.
Converting concat_box_conf as custom op: FlattenConcat_TRT
Warning: No conversion function registered for layer: GridAnchor_TRT yet.
Converting GridAnchor as custom op: GridAnchor_TRT
Converting concat_box_loc as custom op: FlattenConcat_TRT
No. nodes: 661
UFF Output written to /home/god/frozen_inference_graph.uff
UFF Text Output written to /home/god/frozen_inference_graph.pbtxt
where config.py is defined as
import graphsurgeon as gs
import tensorflow as tf
Input = gs.create_node("Input",
op="Placeholder",
dtype=tf.float32,
shape=[1, 3, 300, 300])
PriorBox = gs.create_plugin_node(name="GridAnchor", op="GridAnchor_TRT",
numLayers=6,
minSize=0.2,
maxSize=0.95,
aspectRatios=[1.0, 2.0, 0.5, 3.0, 0.33],
variance=[0.1,0.1,0.2,0.2],
featureMapShapes=[19, 10, 5, 3, 2, 1])
NMS = gs.create_plugin_node(name="NMS", op="NMS_TRT",
shareLocation=1,
varianceEncodedInTarget=0,
backgroundLabelId=0,
confidenceThreshold=1e-8,
nmsThreshold=0.6,
topK=100,
keepTopK=100,
numClasses=91,
inputOrder=[0, 2, 1],
confSigmoid=1,
isNormalized=1)
concat_priorbox = gs.create_node(name="concat_priorbox", op="ConcatV2", dtype=tf.float32, axis=2)
concat_box_loc = gs.create_plugin_node("concat_box_loc", op="FlattenConcat_TRT", dtype=tf.float32, axis=1, ignoreBatch=0)
concat_box_conf = gs.create_plugin_node("concat_box_conf", op="FlattenConcat_TRT", dtype=tf.float32, axis=1, ignoreBatch=0)
namespace_plugin_map = {
"MultipleGridAnchorGenerator": PriorBox,
"Postprocessor": NMS,
"Preprocessor": Input,
"ToFloat": Input,
"image_tensor": Input,
"MultipleGridAnchorGenerator/Concatenate": concat_priorbox,
"MultipleGridAnchorGenerator/Identity": concat_priorbox,
"concat": concat_box_loc,
"concat_1": concat_box_conf
def preprocess(dynamic_graph):
# Now create a new graph by collapsing namespaces
dynamic_graph.collapse_namespaces(namespace_plugin_map)
# Remove the outputs, so we just have a single output node (NMS).
dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
This is the error while running the tensorrt code. I followed the official benchmarking instructions.
god@jetson-nano:/usr/src/tensorrt/bin$ sudo ./sample_uff_ssd_rect
../data/ssd/sample_unpruned_mobilenet_v2.uff
Registering UFF model
Registered Input
Registered output NMS
Creating engine
Begin parsing model...
[libprotobuf FATAL /home/erisuser/p4sw/sw/gpgpu/MachineLearning/DIT/externals/protobuf/aarch64/10.0/include/google/protobuf/repeated_field.h:1408] CHECK failed: (index) < (current_size_):
terminate called after throwing an instance of 'google_private::protobuf::FatalException'
what(): CHECK failed: (index) < (current_size_):
Aborted
