Step1:
Download SSD_mobilenet_v2_coco from tensorflow model zoo
http://download.tensorflow.org/models/object_detection/ssd_mobilenet_v2_coco_2018_03_29.tar.gz
Step2:Modify config.py in /usr/src/tensorrt/samples/sampleUffSSD
import graphsurgeon as gs
import tensorflow as tf
Input = gs.create_node("Input",
op="Placeholder",
dtype=tf.float32,
shape=[1, 3, 300, 300])
PriorBox = gs.create_plugin_node(name="GridAnchor", op="GridAnchor_TRT",
numLayers=6,
minSize=0.2,
maxSize=0.95,
aspectRatios=[1.0, 2.0, 0.5, 3.0, 0.33],
variance=[0.1,0.1,0.2,0.2],
featureMapShapes=[19, 10, 5, 3, 2, 1])
NMS = gs.create_plugin_node(name="NMS", op="NMS_TRT",
shareLocation=1,
varianceEncodedInTarget=0,
backgroundLabelId=0,
confidenceThreshold=1e-8,
nmsThreshold=0.6,
topK=100,
keepTopK=100,
numClasses=91,
#inputOrder=[0, 2, 1],
inputOrder=[1, 0, 2],
confSigmoid=1,
isNormalized=1,
scoreConverter="SIGMOID")
concat_priorbox = gs.create_node(name="concat_priorbox", op="ConcatV2", dtype=tf.float32, axis=2)
concat_box_loc = gs.create_plugin_node("concat_box_loc", op="FlattenConcat_TRT", dtype=tf.float32, axis=1, ignoreBatch=0)
concat_box_conf = gs.create_plugin_node("concat_box_conf", op="FlattenConcat_TRT", dtype=tf.float32, axis=1, ignoreBatch=0)
namespace_plugin_map = {
"MultipleGridAnchorGenerator": PriorBox,
"Postprocessor": NMS,
"Preprocessor": Input,
"ToFloat": Input,
"image_tensor": Input,
"MultipleGridAnchorGenerator/Concatenate": concat_priorbox,
"concat": concat_box_loc,
"concat_1": concat_box_conf
def preprocess(dynamic_graph):
# Now create a new graph by collapsing namespaces
dynamic_graph.collapse_namespaces(namespace_plugin_map)
# Remove the outputs, so we just have a single output node (NMS).
dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
Step3:
sudo python3 /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py ~/test/TRT_object_detection/model/ssd_mobilenet_v2_coco_2018_03_29/frozen_inference_graph.pb -o hello.uff -O NMS -p /usr/src/tensorrt/samples/sampleUffSSD/config.py
Step4:
./detectnet-camera --model=./networks/hello.uff --class_labels=./networks/tmp/ssd_coco_labels.txt
However,some errors:
[gstreamer] initialized gstreamer, version 1.14.5.0
[gstreamer] gstCamera attempting to initialize with GST_SOURCE_NVARGUS, camera 0
[gstreamer] gstCamera pipeline string:
nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=30/1, format=(string)NV12 ! nvvidconv flip-method=0 ! video/x-raw ! appsink name=mysink
nvbuf_utils: Could not get EGL display connection
[gstreamer] gstCamera successfully initialized with GST_SOURCE_NVARGUS, camera 0
detectnet-camera: successfully initialized camera device
width: 1280
height: 720
depth: 12 (bpp)
detectNet -- loading detection network model from:
-- prototxt NULL
-- model ./networks/hello.uff
-- input_blob 'data'
-- output_cvg 'coverage'
-- output_bbox 'bboxes'
-- mean_pixel 0.000000
-- mean_binary NULL
-- class_labels ./networks/tmp/ssd_coco_labels.txt
-- threshold 0.500000
-- batch_size 1
[TRT] TensorRT version 5.0.6
[TRT] loading NVIDIA plugins...
[TRT] completed loading NVIDIA plugins.
[TRT] detected model format - UFF (extension '.uff')
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file ./networks/hello.uff.1.1.GPU.FP16.engine
[TRT] cache file not found, profiling network model on device GPU
[TRT] device GPU, loading /home/jetbot/test/jetson-inference/build/aarch64/bin/ ./networks/hello.uff
[TRT] FeatureExtractor/MobilenetV2/Conv/Relu6: elementwise inputs must have same dimensions or follow broadcast rules (input dimensions were [1,32,150,150] and [1,1,1])
[TRT] FeatureExtractor/MobilenetV2/expanded_conv/depthwise/depthwise: at least three non-batch dimensions are required for input
[TRT] UFFParser: Parser error: FeatureExtractor/MobilenetV2/expanded_conv/depthwise/BatchNorm/batchnorm/mul_1: The input to the Scale Layer is required to have a minimum of 3 dimensions.
[TRT] failed to parse UFF model './networks/hello.uff'
[TRT] device GPU, failed to load ./networks/hello.uff
detectNet -- failed to initialize.
detectnet-camera: failed to load detectNet model
Any solutions about that?
