Deepstream - Failed to register CUDA shared memory
• Hardware Platform (Jetson / GPU) : GPU
• DeepStream Version : 6.1
• TensorRT Version : 8.4.1
• NVIDIA GPU Driver Version (valid for GPU only) : 535.129.03
• Issue Type( questions, new requirements, bugs) : questions
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) :
deepstream으로 다른 docker에서 실행시킨 triton으로 inference를 실행하고자 합니다.
python의 multi process로 여러 프로세스로 inference를 실행하고자 합니다.
그런데 enable_cuda_buffer_sharing을 true로 설정하고 진행하는데 계속 아래와 같은 에러가 발생하는데 이유가 뭐야?
ERROR: infer_grpc_client.cpp:223 Failed to register CUDA shared memory.
ERROR: infer_grpc_client.cpp:311 Failed to set inference input: shared memory region ‘inbuf_0x7faaf00018e0’ already in manager
ERROR: infer_grpc_backend.cpp:140 gRPC backend run failed to create request for model: yolov8_16batch_dynamic
ERROR: infer_grpc_backend.cpp:195 TritonSimple failed to run inference on model yolov8_16batch_dynamic, nvinfer error:NVDSINFER_TRITON_ERROR
• TensorRT Version
• The pipeline being used
  1. How did you start docker? Can you share the specific command line?
  2. Which apps/pipelines are you running? Can you share the steps to reproduce?
  3. Please use English
As an additional supplement, is it consistent with this question?
