where can i find the triton server logs ?
im using docker image triton-server-20.02
in the below thread i see an user had shared the triton server logs . Could you let us know the location of Triton log file
• DeepStream Version
• TensorRT Version
Hardware Platform (Jetson / GPU)
• DeepStream Version 6.1
• TensorRT Version 8.01
ubuntu@ip-172-31-11-102:~$ nvidia-smi
Fri Apr 1 04:03:32 2022
| NVIDIA-SMI 510.47.03 Driver Version: 510.47.03 CUDA Version: 11.6 |
| | | MIG M. |
| 0 Tesla T4 On | 00000000:00:1E.0 Off | 0 |
| N/A 28C P0 25W / 70W | 13531MiB / 15360MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 6150 C tritonserver 13445MiB |
Start triton docker container with appropriate flags to get logs output
can you let me know appropriate flags to be used ?
–log-verbose=3 --log-info=1 --log-warning=1 --log-error=1
“docker run --gpus all --rm --shm-size=1g --ulimit memlock=-1 --ulimit stack=67108864 -p8000:8000 -p8001:8001 -p8002:8002 -vthis_repo_path:/models nvcr.io/nvidia/tritonserver:21.10-py3 tritonserver --model-store=/models --log-verbose=3 --log-info=1 --log-warning=1 --log-error=1”
