im running through docker container tritonserver.21.01 py3 sdk
could some one tell me the parameters to be passed to run simple_grpc_infer_client.py
also could you let know the best sample usecase python code for inferencing Video
• DeepStream Version
• TensorRT Version
Where did you get tritonserver:21.01-py3-sdk container. We only have nvcr.io/nvidia/tritonserver:21.02-py3-sdk
sorry its 21.02 only . i was able to find sample examples , Could you help me out with the path of triton server logs .
when-ever i change/unload/relead the models , where can i see the complete logs
As you know, triton is client server architecture, client sends command to server, server does inferrence.
1 triton sdk does not include inference server, it dose not have triton server logs, please refer to triton docker introdcution Triton Inference Server | NVIDIA NGC
2 client need to send messge to server if need infomation, you can call API triton_client.get_inference_statistics to get module infomation, please refer to demo simple_grpc_infer_client.py, and
here is all API introdcution: GitHub - triton-inference-server/client: Triton Python, C++ and Java client libraries, and GRPC-generated client examples for go, java and scala.
i have a deepstream 6.0 triton docker . and i load the models and start the triton server through
tritonserver --model-repository=model-folder-path
and the model get loaded , and can see the logs whenever they is an change in the model as below ,
I0322 05:41:04.478350 73 server.cc:586]
| Model | Version | Status |
| Fire_model | 1 | READY |
| Fire_onnx_model | 1 | READY |
| Helmet_model | 1 | READY |
| IndianVehicle_model | 1 | READY |
| PPEKit_ONNX | 1 | READY |
| PPEKit_model | 1 | READY |
| Primary_Detector | 1 | READY |
| Secondary_CarColor | 1 | READY |
| Secondary_CarMake | 1 | READY |
| Secondary_VehicleTypes | 1 | READY |
| Segmentation_Industrial | 1 | READY |
| Segmentation_Semantic | 1 | READY |
| TripleRiding_model | 1 | READY |
| densenet_onnx | 1 | READY |
| inception_graphdef | 1 | READY |
| mobilenet_v1 | 1 | READY |
| ssd_inception_v2_coco_2018_01_28 | 1 | READY |
| ssd_mobilenet_v1_coco_2018_01_28 | 1 | READY |
I0322 05:41:04.478471 73 tritonserver.cc:1718]
| Option | Value |
| server_id | triton |
| server_version | 2.13.0 |
| server_extensions | classification sequence model_repository model_repository(unload_dependents) schedule_policy model_configuration system_shared_memor |
| | y cuda_shared_memory binary_tensor_data statistics |
| model_repository_path[0] | /opt/nvidia/deepstream/deepstream-6.0/samples/triton_model_repo/ |
| model_control_mode | MODE_POLL |
| strict_model_config | 1 |
| pinned_memory_pool_byte_size | 268435456 |
| cuda_memory_pool_byte_size{0} | 67108864 |
| min_supported_compute_capability | 6.0 |
| strict_readiness | 1 |
| exit_timeout | 30 |
I0322 05:41:04.820839 73 grpc_server.cc:4111] Started GRPCInferenceService at 0.0.0.0:8001
I0322 05:41:04.832203 73 http_server.cc:2803] Started HTTPService at 0.0.0.0:8000
I0322 05:41:05.005487 73 http_server.cc:162] Started Metrics Service at 0.0.0.0:8002
if i close the terminal , it would be running at the backend , now how it see the logs without restarting tritonserver --model-repository=model-folder-path again
1 can you see the printing above if docker attach the contianer again?
2 if can’t, what is your full docker start command?
when i try to re-attach , i dont have control over tritonserver logs , but the models would be up and running at the backend .
i want to know if any new changes are done , wheather i can see logs . Such as 'model loaded successfully; or ’ failed to load model ’ or 'particular errors ’
1 about " have control over tritonserver logs", do you mean the logs dose not update ?
2 you can use API triton_client.is_model_ready to get model status, please refer to simple_grpc_model_control.py。
how do i view the logs …?? Is there a logfile to view it ?
Also can i get the complete command of ‘triton_client.is_model_ready’
1 no, Triton logs to the console. You can save the logs in a file by redirecting standard output and standard error.
2 please refer to the links below:
protocol
API introduction
is_model_ready usage
