Deepstream triton server config_infer.txt file
m using docker image triton-server-20.02 , how do i change the connection from grpc to http
• DeepStream Version 6.1
• TensorRT Version 8.01
ubuntu@ip-172-31-11-102:~$ nvidia-smi
Fri Apr 1 04:03:32 2022
| NVIDIA-SMI 510.47.03 Driver Version: 510.47.03 CUDA Version: 11.6 |
| | | MIG M. |
| 0 Tesla T4 On | 00000000:00:1E.0 Off | 0 |
| N/A 28C P0 25W / 70W | 13531MiB / 15360MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 6150 C tritonserver 13445MiB |
below is my grpc config connection
triton {
      model_name: "Primary_Detector"
      version: -1
      **grpc {**
**        url: "localhost:8001"**
how do i change to HTTP ???
Hi @h9945394143 ,
As showed in Triton client sample, it can be specified in Triton client - client/image_client.cc at main · triton-inference-server/client · GitHub
im using deepstream application . How can i update the config_infer.txt file from GRPC to HTTP
triton {
      version: -1
      **grpc {**
are you using nvinferserer plugin?
i was able to fix it . thanks
