Secondary classification on triton
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.1.1
• TensorRT Version NGC docker
• NVIDIA GPU Driver Version (valid for GPU only) 525
• Issue Type( questions, new requirements, bugs) Question
I’m trying to implement secondary gie on triton server and connect from deepstream with nvinferserver but I have not been able to find a working example online. I already have a yolov7 working as a primary gie.
I have come up with the config file below, but I’m getting an error. I’d appreciate any help.
CONFIG FILE
infer_config {
  unique_id: 3
  gpu_ids: [0]
  max_batch_size: 1
  backend {
    triton {
      model_name: "vehicle-class"
      version: -1
      grpc {
        url: "localhost:8001"
        enable_cuda_buffer_sharing: false
  preprocess {
    network_format: IMAGE_FORMAT_RGB
    tensor_order: TENSOR_ORDER_LINEAR
    maintain_aspect_ratio: 1
    frame_scaling_hw: FRAME_SCALING_HW_DEFAULT
    frame_scaling_filter: 1
    normalize {
        scale_factor: 1.0
  postprocess {
    labelfile_path: "/app/model/vehicle-class/labels.txt"
  extra {
    copy_input_to_host_buffers: false
input_control {
  process_mode: PROCESS_MODE_CLIP_OBJECTS
  operate_on_gie_id: 1
  operate_on_class_ids: [2,7]
  async_mode: true
ERROR LOG
2023-02-28 11:00:10.499 | SUCCESS  | Pipeline started
2023-02-28 11:00:10.500 | WARNING  | Warning: gst-library-error-quark: NvInferServer asynchronous mode is applicable for secondaryclassifiers only. Turning off asynchronous mode (5) <<-->> gstnvinferserver_impl.cpp(390): validatePluginConfig (): /GstPipeline:pipeline0/GstBin:infer-1/GstNvInferServer:vehicle-class-infer-1
2023-02-28 11:00:10.500 | ERROR    | Error: gst-resource-error-quark: Failed to initialize InferTrtIsContext (1) <<-->> gstnvinferserver_impl.cpp(547): start (): /GstPipeline:pipeline0/GstBin:infer-1/GstNvInferServer:vehicle-class-infer-1:
Config file path: /app/gies/vehicle-class.txt
2023-02-28 11:00:10.500 | WARNING  | Pipeline stopped
please refer to deepstream SDK native sample opt\nvidia\deepstream\deepstream-6.1.1\samples\configs\deepstream-app-triton-grpc. it supports nvinferserver pgie+sgie.
