[DeepStream 6.0] Getting 'GstNvInferServer' has no property named 'input-tensor-meta' error while running triton example through Deepstream-app
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.0
• TensorRT Version
Container Image : nvcr.io/nvidia/deepstream:6.0-triton
I am trying to run triton examples and I am getting below error with Nividia Container image nvcr.io/nvidia/deepstream:6.0-triton. Can anyone help please?
source30_1080p_dec_infer-resnet_tiled_display_int8.txt source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
root@fe9e26dca43b:/opt/nvidia/deepstream/deepstream-6.0# deepstream-app -c samples/configs/deepstream-app-triton-grpc/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
(deepstream-app:2097): GLib-GObject-WARNING **: 09:27:50.039: g_object_set_is_valid_property: object class ‘GstNvInferServer’ has no property named ‘input-tensor-meta’
** INFO: <create_primary_gie_bin:146>: gpu-id: 0 in primary-gie group is ignored, only accept in nvinferserver’s config
** ERROR: main:658: Failed to set pipeline to PAUSED
Quitting
App run failed
There is no such property of ‘output_tensor_meta’ of nvinferserver plugin.
There is only “output_tensor_meta” config in nvinferserver plugin features . Gst-nvinferserver — DeepStream 6.1.1 Release documentation
You need to config in the config file. E.G. /opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-infer-tensor-meta-test/inferserver/dstensor_pgie_config.txt
Thanks @Fiona.Chen for feedback.
I have used prebuilt file supplied as part of triton server container image, I will try removing same and update.
