• Hardware Platform (Jetson / GPU) : Jetson Orin Nano
• DeepStream Version: DeepStream 7.1
• JetPack Version (valid for Jetson only) JatPack 6.1
• TensorRT Version 10.3.0.30
My
Building the TensorRT Engine
Building complete
but after that I’m receiving error as below :-
0:29:34.433267382 18902 0xaaaae040f0a0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2138> [UID = 1]: serialize cuda engine to file: /Storage/DeepStream-Yolo/model_b1_gpu0_fp16.engine successfully
Implicit layer support has been deprecated
INFO: [Implicit Engine Info]: layers num: 0
0:29:34.943073530 18902 0xaaaae040f0a0 ERROR nvinfer gstnvinfer.cpp:678:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initResource() <nvdsinfer_context_impl.cpp:841> [UID = 1]: Detect-postprocessor failed to init resource because dlsym failed to get func NvDsInferParseYolo pointer
ERROR: Infer Context failed to initialize post-processing resource, nvinfer error:NVDSINFER_CUSTOM_LIB_FAILED
ERROR: Infer Context prepare postprocessing resource failed., nvinfer error:NVDSINFER_CUSTOM_LIB_FAILED
0:29:35.011187453 18902 0xaaaae040f0a0 WARN nvinfer gstnvinfer.cpp:914:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:29:35.011248248 18902 0xaaaae040f0a0 WARN nvinfer gstnvinfer.cpp:914:gst_nvinfer_start:<primary_gie> error: Config file path: /Storage/DeepStream-Yolo/config_infer_primary_yoloV9.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
ERROR: main:713: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(914): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
What did I do wrong?
I’m clueless here. Your guidance much appreciated
Best regards,
Sebastian
