• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 5.0
• TensorRT Version 7.0.0.11
• Issue Type( questions, new requirements, bugs) bug
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
0:00:27.838879250 29 0x1656b760 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/data/gcs/dt-model-store/62ad37ae6ad4cf7f61ec46a1/tensorrt.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_0 3x224x224
1 OUTPUT kFLOAT output_0 96x1x1
0:00:27.839029628 29 0x1656b760 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1642> [UID = 1]: Backend has maxBatchSize 1 whereas 4 has been requested
0:00:27.839124284 29 0x1656b760 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1813> [UID = 1]: deserialized backend context :/data/gcs/dt-model-store/62ad37ae6ad4cf7f61ec46a1/tensorrt.engine failed to match config params, trying rebuild
0:00:27.842821789 29 0x1656b760 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:934 failed to build network since there is no model file matched.
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:872 failed to build network.
0:00:27.843208223 29 0x1656b760 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1735> [UID = 1]: build engine file failed
0:00:27.843245125 29 0x1656b760 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1821> [UID = 1]: build backend context failed
0:00:27.843266884 29 0x1656b760 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1148> [UID = 1]: generate backend failed, check config file settings
0:00:27.843759262 29 0x1656b760 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary-inference> error: Failed to create NvDsInferContext instance
0:00:27.843785936 29 0x1656b760 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start:<primary-inference> error: Config file path: /tmp/nvinfer-config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInfer
facing this issue while trying out deepstream with multiple input streams, although older models used to work fine.
we use a custom model and convert it to trt try using torch2trt.
model_tensorrt = torch2trt(model, [dummy_input], max_batch_size=64)
max_batch_size is 64 at the time of trt engine creation.
