Deepstream
issue:deepstream-app: error while loading shared libraries: libnvinfer.so.7: cannot open shared object file: No such file or directory
• Hardware Platform (Jetson nano)
• DeepStream Version5.1
• JetPack Version (4.6)
• 8.0
• Install deepstream to run the test statements inside:deepstream-app -c source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt
i saw thiserror:deepstream-app: error while loading shared libraries: libnvinfer.so.7: cannot open shared object file: No such file or directory,
and i run deepstream-app --version-all,the error is same.I’ve added tensorrt paths to the environment variables
Sorry for the late response, is this still an issue to support? Thanks
Jetpack 4.6 support Deepstream 6.0
thanks so much , i have solved this problem.I ran into the following issues using my own model to deploy via deepstream:Failed to create NvDsInferContext instance .
  • yolov5-5.0
  • jetpack-4.4
  • deepstream-5.0
  • Tensorrt-7.1
  • Cuda-10.2
Perform the last step:LD_PRELOAD=./libmyplugins.so deepstream-app -c deepstream_app_config_yoloV5.txt
I received the following error:
  1. ERROR from primary_gie: Failed to create NvDsInferContext instance
  2. Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(809): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
  3. Config file path: /home/yqy/workspace/Yolov5-mask-detect-in-Deepstream-5.0-tensorrt7/Deepstream 5.0/config_infer_primary_yoloV5.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
  4. App run failed
