**• Hardware Platform (Jetson / GPU) GPU
**• DeepStream Version 6.0.1
deepstream-app version 6.0.1
DeepStreamSDK 6.0.1
CUDA Driver Version: 11.4
CUDA Runtime Version: 11.4
TensorRT Version: 8.0
cuDNN Version: 8.9
libNVWarp360 Version: 2.0.1d3
run sudo deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt error
error: Config file path: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_infer_primary.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
0:00:00.824150517 3862 0x5609bc610950 WARN GST_PADS gstpad.c:1149:gst_pad_set_active:<primary_gie:sink> Failed to activate pad
[NvMultiObjectTracker] De-initialized
** ERROR: main:707: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
