Hi,I successfully deployed my model but the frame rate was very low, only 7 frames, I used logitech’s c920 model, the parameters are as follows:[source0]
enable=1 #Type - 1=CameraV4L2 2=URI 3=MultiURI
type=1
camera-width=1280
camera-height=720
camera-fps-n=30
camera-v4l2-dev-node=0
#uri=file://…/…/samples/streams/sample_1080p_h264.mp4
num-sources=1
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
What precision or format should I use to improve the frame rate, thanks
what’s the HW platform?
What inference precision did you choose?
you can use command like below to check the model perf # /usr/src/tensorrt/bin/trtexec --loadEngine=TRT_Engine_Generated_by_DeepStream --plugins=./libmyplugins.so
