Deepstream python app deepstream-test2 change nvinfer to YOLOv3
Hi
I am testing deepstream-test2 and I want to change the model to YOLOv3.
I looked at objectDetection_Yolo and copied the config file config_infer_primary_yoloV3.txt, yolov3.cfg, yolov3.weights, labels.txt, and yolov3-calibration.table.trt7.0 to deepstream-test2.
When I run python3 deepstream_test_3.py. The following error occured. Please help.
0:00:00.242715079 9077 0x9104af0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
ERROR: failed to build network since there is no model file matched.
ERROR: failed to build network.
0:00:01.428743915 9077 0x9104af0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1735> [UID = 1]: build engine file failed
0:00:01.428973807 9077 0x9104af0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1821> [UID = 1]: build backend context failed
0:00:01.429076178 9077 0x9104af0 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1148> [UID = 1]: generate backend failed, check config file settings
0:00:01.429177044 9077 0x9104af0 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:01.429267765 9077 0x9104af0 WARN nvinfer gstnvinfer.cpp:809:gst_nvinfer_start: error: Config file path: dstest2_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(809): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Exiting app
i tried using config_infer_primary_yoloV3.txt directly by renaming it and tried just modify the model file as listed below. Both failed
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
#model-file=…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel
#proto-file=…/…/…/…/samples/models/Primary_Detector/resnet10.prototxt
#model-engine-file=…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
#labelfile-path=…/…/…/…/samples/models/Primary_Detector/labels.txt
#int8-calib-file=…/…/…/…/samples/models/Primary_Detector/cal_trt.bin
custom-network-config=./yolov3.cfg
model-file=./yolov3.weights
labelfile-path=./labels.txt
int8-calib-file=./yolov3-calibration.table.trt7.0
force-implicit-batch-dim=1
batch-size=1
network-mode=1
process-mode=1
model-color-format=0
num-detected-classes=4
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
#scaling-filter=0
#scaling-compute-hw=0
[class-attrs-all]
pre-cluster-threshold=0.2
eps=0.2
group-threshold=1
You need to change the corresponding nvinfer config file
