Hey guys, I got an error when try to ‘deepstream-app -c deepstream_app_config_yoloV3.txt’ and perform a deepsream-python-app:
desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_Yolo$ deepstream-app -c deepstream_app_config_yoloV3.txt
Unknown or legacy key specified ‘is-classifier’ for group [property]
Warn: ‘threshold’ parameter has been deprecated. Use ‘pre-cluster-threshold’ instead.
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
0:00:00.246684862 9116 0x30718690 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
Loading pre-trained weights…
Loading weights of yolov3 complete!
Total Number of weights read : 62001757
terminate called after throwing an instance of ‘std::out_of_range’
what(): map::at
Aborted (core dumped)
key point:
terminate called after throwing an instance of 'std::out_of_range’
** what(): map::at**
I did the same work before and they were fine,
now I use a new device with JP4.4.1, deepstream5.0.1, tensorrt7.1.3,
how to fix the problem?
thx
cy
