Deepstream-test3-app error
**• Jetson NX
**• DeepStream Version5.1
**• JetPack Version 4.5,Ubuntu18.04
**• TensorRT Version 7.1
**• yolov5s.engine
Hi,i have successfully run the base program of"deepstream-test3-app" and use yolov5s.engine for single channel RTSP processing,but when i use multi-channel RTSP input is ERROR.Please help me,thanks.
example single: ./deepstream-test3-app ‘rtsp://admin:byzt-2018@192.168.1.108:554/cam/realmonitor?channel=1&subtype=1’
example multi(ERROR): ./deepstream-test3-app ‘rtsp://admin:byzt-2018@192.168.1.108:554/cam/realmonitor?channel=1&subtype=1’ ‘rtsp://admin:byzt-2018@192.168.1.108:554/cam/realmonitor?channel=1&subtype=1’
my dstest3_pgie_config.txt:
[property]
gpu-id=0
force-implicit-batch-dim=1
net-scale-factor=0.0039215697906911373
model-color-format=0
model-engine-file=yolov5s.engine
labelfile-path=labels.txt
num-detected-classes=80
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=4
batch-size=2
maintain-aspect-ratio=0
parse-bbox-func-name=NvDsInferParseCustomYoloV5
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
[class-attrs-all]
pre-cluster-threshold=0.25
ERROR:
Now playing: rtsp://admin:byzt-2018@192.168.1.108:554/cam/realmonitor?channel=1&subtype=1, rtsp://admin:byzt-2018@192.168.1.108:554/cam/realmonitor?channel=1&subtype=1,
Using winsys: x11
0:00:04.770858648 11863 0x558d9b4400 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.1/sources/yolov5-5.0/yolov5s.engine
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT data 3x640x960
1 OUTPUT kFLOAT prob 6001x1x1
0:00:04.771146457 11863 0x558d9b4400 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1643> [UID = 1]: Backend has maxBatchSize 1 whereas 2 has been requested
0:00:04.771207961 11863 0x558d9b4400 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1814> [UID = 1]: deserialized backend context :/opt/nvidia/deepstream/deepstream-5.1/sources/yolov5-5.0/yolov5s.engine failed to match config params, trying rebuild
0:00:04.806984321 11863 0x558d9b4400 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
ERROR: failed to build network since there is no model file matched.
ERROR: failed to build network.
0:00:04.808547975 11863 0x558d9b4400 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1736> [UID = 1]: build engine file failed
0:00:04.808614471 11863 0x558d9b4400 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1822> [UID = 1]: build backend context failed
0:00:04.808671559 11863 0x558d9b4400 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1149> [UID = 1]: generate backend failed, check config file settings
0:00:04.809142345 11863 0x558d9b4400 WARN nvinfer gstnvinfer.cpp:812:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:04.809216041 11863 0x558d9b4400 WARN nvinfer gstnvinfer.cpp:812:gst_nvinfer_start: error: Config file path: dstest3_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Running…
ERROR from element primary-nvinference-engine: Failed to create NvDsInferContext instance
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(812): gst_nvinfer_start (): /GstPipeline:dstest3-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Deleting pipeline
How did you generate the “yolov5s.engine” file? What is your original model? Your engine does not match the config you set in the config file. Please check your configs.
