Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating source_bin 1
Creating source bin
source-bin-01
Creating source_bin 2
Creating source bin
source-bin-02
Creating source_bin 3
Creating source bin
source-bin-03
Creating Pgie
Creating nvvidconv1
Creating filter1
Creating tiler
Creating nvvidconv
Creating nvosd
Creating transform
Creating EGLSink
Atleast one of the sources is live
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing…
1 : rtsp://admin:Fire1000@192.168.1.105/Streaming/Channels/103
2 : rtsp://admin:Fire1000@192.168.1.103/Streaming/Channels/103
3 : rtsp://admin:Fire1000@192.168.1.102/Streaming/Channels/103
4 : rtsp://admin:Fire1000@192.168.1.106/Streaming/Channels/103
Starting pipeline
Using winsys: x11
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:05.580961936 23882 0x3861b860 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/dong.engine
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT data 3x640x640
1 OUTPUT kFLOAT prob 6001x1x1
0:00:05.581170325 23882 0x3861b860 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1833> [UID = 1]: Backend has maxBatchSize 1 whereas 4 has been requested
0:00:05.581213590 23882 0x3861b860 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: deserialized backend context :/opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/dong.engine failed to match config params, trying rebuild
0:00:05.619096375 23882 0x3861b860 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
ERROR: failed to build network since there is no model file matched.
ERROR: failed to build network.
0:00:05.620211087 23882 0x3861b860 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:05.620294609 23882 0x3861b860 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:05.620332914 23882 0x3861b860 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:05.621322022 23882 0x3861b860 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:05.621380680 23882 0x3861b860 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start: error: Config file path: dstest_multi.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Exiting app
