deepstream-app -c deepstream_app_config.txt
Failed to load config file: Key file contains line ?0000[property]? which is not a key-value pair, group, or comment
** ERROR: <gst_nvinfer_parse_config_file:1303>: failed
Using winsys: x11
0:00:00.262846898 12988 0x1d9232c0 WARN nvinfer gstnvinfer.cpp:794:gst_nvinfer_start:<primary_gie> error: Configuration file parsing failed
0:00:00.262921951 12988 0x1d9232c0 WARN nvinfer gstnvinfer.cpp:794:gst_nvinfer_start:<primary_gie> error: Config file path: /home/iisl/Desktop/opt/nvidia/deepstream/deepstream-6.0/sources/DeepStream-Yolo-master/config_infer_primary_yoloV5.txt
** ERROR: main:658: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Configuration file parsing failed
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(794): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
