I get this error all the time after running my config file for all yolo versions
• Hardware Platform (Jetson / GPU) Jetson xavier
• DeepStream Version 5.0
• TensorRT Version
Hi guys,
I get this error all the time after running my config file:
Error: Could not parse custom library path
Failed to parse group property
** ERROR: <gst_nvinfer_parse_config_file:1242>: failed
Using winsys: x11
0:00:00.247908588 31374 0x32427cf0 WARN nvinfer gstnvinfer.cpp:766:gst_nvinfer_start:<primary_gie> error: Configuration file parsing failed
0:00:00.247991629 31374 0x32427cf0 WARN nvinfer gstnvinfer.cpp:766:gst_nvinfer_start:<primary_gie> error: Config file path: /home/pi/lo/configs/config_infer_primary_yoloV3.txt
** ERROR: main:655: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Configuration file parsing failed
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(766): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
Any suggestion?
Could you share this file ?
This is config_infer_primary_yoloV2.txt
[property]
gpu-id=0
net-scale-factor=1
#0=RGB, 1=BGR
model-color-format=0
custom-network-config=/home/pi/lo/models/yolo/yolov2.cfg
model-file=/home/pi/lo/models/yolo/yolov2.weights
model-engine-file=/home/pi/lo/models/yolo/yolov2.model_b1_fp32.engine
labelfile-path=/home/pi/lo/models/yolo/labels.txt
0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
num-detected-classes=80
gie-unique-id=1
is-classifier=0
maintain-aspect-ratio=1
parse-bbox-func-name=NvDsInferParseCustomYoloV2
custom-lib-path=/opt/nvidia/deepstream/deepstream/sources/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.$
this is not right! Please refer to yolov sample - /opt/nvidia/deepstream/deepstream/sources/objectDetector_Yolo/
Thank you !
