I am testing peoplenet in deepstream on AGX Xaiver and I have error as follows.
failed to parse group property
** ERROR: <gst_nvinfer_parse_config_file:1158>: failed
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
0:00:00.198028383 12688 0x7f4c002380 WARN nvinfer gstnvinfer.cpp:747:gst_nvinfer_start:<primary_gie> error: Configuration file parsing failed
0:00:00.198092705 12688 0x7f4c002380 WARN nvinfer gstnvinfer.cpp:747:gst_nvinfer_start:<primary_gie> error: Config file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/tlt_pretrained_models/config_infer_primary_peoplenet.txt
** ERROR: <main:651>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Configuration file parsing failed
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(747): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
My config files are
config_infer_primary_peoplenet.txt (1.2 KB) deepstream_app_source1_peoplenet.txt (2.5 KB)
I run the app as
deepstream-app -c /opt/nvidia/deepstream/deepstream-5.0/samples/configs/tlt_pretrained_models/deepstream_app_source1_peoplenet.txt
What could be wrong?
