Error: Could not parse TLT encoded model file path
Failed to parse group property
** ERROR: <gst_nvinfer_parse_config_file:1242>: failed
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
0:00:00.343254430 31869 0x2ebbbf30 WARN nvinfer gstnvinfer.cpp:766:gst_nvinfer_start:<primary_gie> error: Configuration file parsing failed
0:00:00.343321879 31869 0x2ebbbf30 WARN nvinfer gstnvinfer.cpp:766:gst_nvinfer_start:<primary_gie> error: Config file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/tlt_pretrained_models/config_infer_primary_peoplenet.txt
** ERROR: <main:655>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Configuration file parsing failed
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(766): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
App run failed
I checked the config file at Primary GIE group and found that the model engine file is not in the identified folder, where should I get this file?
[primary-gie]
enable=1
gpu-id=0
model-engine-file=…/…/models/tlt_pretrained_models/peoplenet/resnet34_peoplenet_pruned.etlt_b1_gpu0_fp16.engine
batch-size=1 #Required by the app for OSD, not a plugin property
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
gie-unique-id=1
config-file=config_infer_primary_peoplenet.txt
The sample config file use relative path instead of absolute path, so either you go into the /opt/nvidia/deepstream/deepstream-5.0/samples/configs/tlt_pretrained_models folder and run the command “deepstream-app -c deepstream_app_source1_peoplenet.txt”, or you need to modify the config file /opt/nvidia/deepstream/deepstream-5.0/samples/configs/tlt_pretrained_models/deepstream_app_source1_peoplenet.txt to change all relative path in it to absolute path.
Hi @Fiona.Chen
I tried to run the command deepstream-app -c deepstream_app_source1_peoplenet.txt under /opt/nvidia/deepstream/deepstream-5.0/samples/configs/tlt_pretrained_models
but I still get the error like this
Using winsys: x11
0:00:00.242334378 19299 0x7f30002380 WARN nvinfer gstnvinfer.cpp:766:gst_nvinfer_start:<primary_gie> error: Configuration file parsing failed
0:00:00.242411047 19299 0x7f30002380 WARN nvinfer gstnvinfer.cpp:766:gst_nvinfer_start:<primary_gie> error: Config file path: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/tlt_pretrained_models/config_infer_primary_peoplenet.txt
** ERROR: main:655: Failed to set pipeline to PAUSED
Quitting
App run failed
I also changed the tlt-encoded-model in infer config file to /opt/nvidia/deepstream/deepstream-5.0/samples/models/tlt_pretrained_models/peoplenet/resnet34_peoplenet_pruned.etlt from /opt/nvidia/deepstream/deepstream-5.0/samples/models/tlt_peoplenet_pruned_v1.0/resnet34_peoplenet_pruned.etlt as default
Since you are using absolute path in your config file and there is no engine file for the first time, you need to comment out the model-engine-file=xxxx setting in your config file.
And if you want the engine file being generated, please run with root account for at least one time. And then you can set model-engine-file=xxxx in your config file and run the case.
