• Hardware Platform : GTX1080TI
• DeepStream version : 5.0
• TensorRT version : 7.0
• NVIDIA GPU Driver Version : 440.33.01
• Issue type : bugs
I am running deepstream_test-1, I followed all of this README to execute on deepstream docker
Playing file /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4
Error: Could not parse model engine file path
Failed to parse group property
** ERROR: <gst_nvinfer_parse_config_file:1242>: failed
Adding elements to Pipeline
Actually, I solved the problem but I had to generate the resnet10.caffemodel_b1_gpu0_int8.engine running the make file in /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1
But suppose I just want to run only in python (/opt/nvidia/deepstream/deepstream-5.0/sources/python/), how to do it? because I had to use C files to creat it or I am wrong?
Obviously, because It cant find .engine file.
So, the python program doesn’t create this file automatically as I see, idk why, unlike of this program (/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test1/deepstream_test1), which do create it.
When you give it path started with “/”, it will run into below “if (file_path[0] == ‘/’) {” and fail on realpath() function, and then report Error - “Error: Could not parse model engine file path” because the engine file does not exist.
Maybe this is a bug of DeepStream, we will discuss this internally,
I found that it still couldn’t support the absolute path.
Have we had it fixed later on?
And I’d like to know what the realpath function is doing?
