I am facing an issue while trying to read the tensorrt engine file for the deepstream_launchpad.ipynb code. I am trying to use my .engine file within the dslaunchpad_pgie_config.txt file and it does not seem to recognise the file, the error below:
0:00:00.758867392 82130 0x1fc662d0 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1174> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
ERROR: [TRT]: 1: [pluginV2Runner.cpp::load::299] Error Code 1: Serialization (Serialization assertion creator failed.Cannot deserialize plugin since corresponding IPluginCreator not found in Plugin Registry)
ERROR: [TRT]: 4: [runtime.cpp::deserializeCudaEngine::65] Error Code 4: Internal Error (Engine deserialization failed.)
ERROR: Deserialize engine failed from file: /opt/nvidia/deepstream/deepstream-6.3/samples/models/Primary_Detector/side_textarea.engine
0:00:03.250602720 82130 0x1fc662d0 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1976> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.3/samples/models/Primary_Detector/side_textarea.engine failed
0:00:03.439277280 82130 0x1fc662d0 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2081> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.3/samples/models/Primary_Detector/side_textarea.engine failed, try rebuild
0:00:03.439323328 82130 0x1fc662d0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: Trying to create engine from model files
ERROR: failed to build network since there is no model file matched.
ERROR: failed to build network.
0:00:05.135518336 82130 0x1fc662d0 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2022> [UID = 1]: build engine file failed
0:00:05.305624128 82130 0x1fc662d0 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2108> [UID = 1]: build backend context failed
0:00:05.305671168 82130 0x1fc662d0 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1282> [UID = 1]: generate backend failed, check config file settings
0:00:05.305735712 82130 0x1fc662d0 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<primary-inference> error: Failed to create NvDsInferContext instance
0:00:05.305771296 82130 0x1fc662d0 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<primary-inference> error: Config file path: ./configs/dslaunchpad_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(898): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
This is the config file ( dslaunchpad_pgie_config.txt):
# SPDX-FileCopyrightText: Copyright (c) 2019-2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: Apache-2.0
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
# Following properties are mandatory when engine files are not specified:
# int8-calib-file(Only in INT8)
# Caffemodel mandatory properties: model-file, proto-file, output-blob-names
# UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
# ONNX: onnx-file
# Mandatory properties for detectors:
# num-detected-classes
# Optional properties for detectors:
# cluster-mode(Default=Group Rectangles), interval(Primary mode only, Default=0)
# custom-lib-path,
# parse-bbox-func-name
# Mandatory properties for classifiers:
# classifier-threshold, is-classifier
# Optional properties for classifiers:
# classifier-async-mode(Secondary mode only, Default=false)
# Optional properties in secondary mode:
# operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
# input-object-min-width, input-object-min-height, input-object-max-width,
# input-object-max-height
# Following properties are always recommended:
# batch-size(Default=1)
# Other optional properties:
# net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
# model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
# mean-file, gie-unique-id(Default=0), offsets, process-mode (Default=1 i.e. primary),
# custom-lib-path, network-mode(Default=0 i.e FP32)
# The values in the config file are overridden by values set through GObject
# properties.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
#model-file=../../../../samples/models/Primary_Detector/resnet10.caffemodel
#proto-file=../../../../samples/models/Primary_Detector/resnet10.prototxt
#model-engine-file=../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
model-engine-file=../../../../samples/models/Primary_Detector/side_textarea.engine
labelfile-path=../../../../samples/models/Primary_Detector/labels.txt
#int8-calib-file=../../../../samples/models/Primary_Detector/cal_trt.bin
force-implicit-batch-dim=1
batch-size=1
network-mode=1
num-detected-classes=1
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
#scaling-filter=0
#scaling-compute-hw=0
[class-attrs-all]
pre-cluster-threshold=0.2
eps=0.2
group-threshold=1
Board: Jetson AGX Xavier
Cuda: 11.4
Deepstream 6.3
Additionally, I followed this link for the config params: Gst-nvinfer — DeepStream documentation 6.4 documentation
Any help would be appreciated, thanks.
Regards,
Neville
