Load only .engine file
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.0.1.6
I have trained a pytorch model, best.pt. For I used GhostConv & DWConv etc. layers,
it’s difficult to convert to right .cfg and .wts via gen_wts_yoloV5.py in Deepstream-Ylo
or in tensorrtx. So I exported to onnx in yolov5, then use trtexec to produce the .engine
file.
Now I want load the .engine file directly from deepstream without .cfg and .wts, but not succeeded.
deepstream-app -c deepstream_app_config.txt
Using winsys: x11
0:00:05.465532190 21034 0xf7b1f50 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/sources/DeepStream-Yolo/./best_exp.engine
INFO: [Implicit Engine Info]: layers num: 5
0 INPUT kHALF images 3x640x640
1 OUTPUT kHALF 490 3x80x80x6
2 OUTPUT kHALF 558 3x40x40x6
3 OUTPUT kHALF 626 3x20x20x6
4 OUTPUT kFLOAT output 25200x6
0:00:05.465893821 21034 0xf7b1f50 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/sources/DeepStream-Yolo/./best_exp.engine
0:00:05.475766009 21034 0xf7b1f50 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.0/sources/DeepStream-Yolo/config_infer_primary_yoloV5.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:194>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 260
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 260
** INFO: <bus_callback:180>: Pipeline running
WARNING: Num classes mismatch. Configured: 1, detected by network: 0
deepstream-app: nvdsparsebbox_Yolo.cpp:137: bool NvDsInferParseCustomYolo(const std::vector&, const NvDsInferNetworkInfo&, const NvDsInferParseDetectionParams&, std::vector&, const uint&, const uint&): Assertion `layer.inferDims.numDims == 3’ failed.
Aborted (core dumped)
deepstream_app_config.txt:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=2
sync=0
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=5
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=1
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tests]
file-loop=0
config_infer_primary_yoloV5.txt:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
custom-network-config=yolov5n.cfg
model-file=yolov5n.wts
model-engine-file=model_b1_gpu0_fp32.engine
#int8-calib-file=calib.table
labelfile-path=labels.txt
batch-size=1
network-mode=0
num-detected-classes=1
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
parse-bbox-func-name=NvDsInferParseYolo
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.25
How to fix this error? Or, is it possible to run without .cfg and .wts?
The post-processor -NvDsInferParseYolo() function defined in “parse-bbox-func-name=NvDsInferParseYolo” does not meet your model, you need to modify it to adopt your model.
You may could refer to GitHub - beyondli/Yolo_on_Jetson
Thank you much. I will try it.
As per Yolo_on_Jetson case, I failed to convert .pt to .onnx, for my .pt applied ghostconv which not defined in common.py,. I customed the common.py, yet it not work.
And I exported onnx via yolov5 b6.1, and copied it to the docker container, and tensorrt succeeded to output a .engine
But when I try to integrate it with deepstream, errors appeared as follows:
(p3) shisun@nx:~/Yolo_on_Jetson/deepstream$ deepstream-app -c deepstream_app_config.txt
Using winsys: x11
0:00:04.279979065 25951 0x12cca2a0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/home/shisun/Yolo_on_Jetson/deepstream/best.engine
1 OUTPUT kHALF 485 3x80x80x6
2 OUTPUT kHALF 545 3x40x40x6
3 OUTPUT kHALF 605 3x20x20x6
0:00:04.280289368 25951 0x12cca2a0 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /home/shisun/Yolo_on_Jetson/deepstream/best.engine
0:00:04.292904919 25951 0x12cca2a0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/home/shisun/Yolo_on_Jetson/deepstream/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
deepstream-app: nvdsparsebbox_Yolo.cpp:203: bool NvDsInferParseCustomYolo(const std::vector&, const NvDsInferNetworkInfo&, const NvDsInferParseDetectionParams&, std::vector&, const uint&, const uint&): Assertion `layer.inferDims.numDims == 3 || layer.inferDims.numDims == 4’ failed.
deepstream_app.config.txt
[application]
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
uri=file:/home/shisun/81fd5.mp4
#uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[osd]
enable=1
gpu-id=0
border-width=5
text-size=15
text-color=1;1;1;1;
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=1
width=640
height=640
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=0
[tests]
file-loop=0
[property]
gpu-id=0
#model-engine-file=./models/yolov5s_fp32.engine
#network-mode=0
model-engine-file=/home/shisun/Yolo_on_Jetson/deepstream/best.engine
network-mode=2
#model-engine-file=./models/yolov5s_int8.engine
#int8-calib-file=./models/yolov5s_calibration.cache
#network-mode=1
network-input-order=0
#infer-dims=640;640;3
symmetric-padding=1
batch-size=1
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
[class-attrs-all]
nms-iou-threshold=0.3
pre-cluster-threshold=0.5
发件人:mchi via NVIDIA Developer Forums nvidia@discoursemail.com
发送日期:2022-05-30 16:01:32
收件人:zqsun@shsunimage.com
主题:[NVIDIA Developer Forums] [Intelligent Video Analytics/DeepStream SDK] Load only .engine file
or kindly info me which file shall I modify?
Thank you very much
These error are from the post-processor code under /opt/nvidia/deepstream/deepstream/sources/objectDetector_Yolo/nvdsinfer_custom_impl_Yolo, you need to understand the meaning of each output of your model and modify the post-processor code under nvdsinfer_custom_impl_Yolo accordingly. These post-processor code are for YoloV3, you need to modify them to make them work for your model
Thank you for quick reply. I am tring.
I tried Yolo-on-Jetson and it works with FP32 trt model.
However the fps is around 30. And I need to run my model on FP16 to
get higher fps. How to modify the nvdsbboxparseyolo.cpp?
Thank you.
did you build this FP32 model outside of DeepStream?
yes. I built with trtexec for I cannot convert it to wts ang cfg.
Do I need to redefine all float type to kHALF, or how to let C++ to load
the right fp16 data from trt file?
you can build the fp16 image with trtexec, and keep “network-mode=2”.
No, you just need to specify the fp16 option in trtexec command.
Thank you for reply.
I tried fp16 option in generating engine file and keeo mode=2 in the configuation file. And deepstream starts like below:
const std::vector<const NvDsInferLayerInfo*> sortedLayers =
SortLayers (outputLayersInfo);
std::vector<NvDsInferParseObjectInfo> objects;
for (uint idx = 0; idx < outputLayersInfo.size(); ++idx)
    const NvDsInferLayerInfo &layer = *sortedLayers[idx];
    assert(layer.inferDims.numDims == 3 || layer.inferDims.numDims == 4);
when going to this “assert”, error occured. I found the idx=0 layer is 25200x6
so I changed below:
original code: for (uint idx = 0; idx < outputLayersInfo.size(); ++idx)
modified: for (uint idx = 1; idx < outputLayersInfo.size(); ++idx)
then above error disappeared. but when going to idx=3
3x80x80x80
another error appeared:
Segmentaion fault, core dumped.
Continue:
when I running fp32 model via Yolo_on_Jetson, it works:
Using winsys: x11
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:05.933134080 9207 0x7f2c002290 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/home/shisun/Yolo_on_Jetson/deepstream _61/models/best61.trt
0 INPUT kFLOAT images 3x640x640
1 OUTPUT kFLOAT 485 3x80x80x6
2 OUTPUT kFLOAT 543 3x40x40x6
3 OUTPUT kFLOAT 601 3x20x20x6
0:00:05.933577632 9207 0x7f2c002290 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /home/shisun/Yolo_on_Jetson/deepstream _61/models/best61.trt
0:00:05.950792288 9207 0x7f2c002290 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/home/shisun/Yolo_on_Jetson/deepstream _61/config_infer_primary.txt sucessfully
hi,
I regererated trt file with only fp16 option, no other optimization option. And now fp16 model works, no need for api modification.
Thank you very much.
Coool! So we can close this?
ok
