Triton server labels
• Hardware Platform (Jetson / GPU) tesla t4
• DeepStream Version 6.1
• TensorRT Version 8.1
input config file:  config/config
1
Doneeee
Creating streamux
 i****************** 0
Creating source_bin  0
Creating Pgie
Creating nvvidconv1
Creating filter1
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
WARNING: Overriding infer-config batch-size 0  with number of sources  1
Creating nvtracker
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing...: /opt/nvidia/deepstream/deepstream-6.0/sources/deepstream-apps/extraSTUFF/gun6.jpg
Starting pipeline
0:00:00.488963193  3493      0x5dc1e70 WARN           nvinferserver gstnvinferserver_impl.cpp:284:validatePluginConfig:<primary-inference> warning: Configuration file batch-size reset to: 1
INFO: infer_grpc_backend.cpp:164 TritonGrpcBackend id:1 initialized for model: Fire_model
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvTrackerParams::getConfigRoot()] !!![WARNING] Empty config file path is provided. Will go ahead with default values
[NvMultiObjectTracker] Initialized
Warning: gst-library-error-quark: Configuration file batch-size reset to: 1 (5): gstnvinferserver_impl.cpp(284): validatePluginConfig (): /GstPipeline:pipeline0/GstNvInferServer:primary-inference
\n pgie_sink_pad_buffer_probe
Frame Number is  0
Source id is  0
Batch id is  0
Source Frame Width  1200
Source Frame Height  630
Num object meta  0
osd l_obj None
frameNumber: 0 totalFireCount: 0
**WARNING: Num classes mismatch. Configured: 3, detected by network: 0**
metadataInfomation {'numberOfObjects': 0, 'gunCount': 0, 'fireCount': 0, 'rifleCount': 0}
im getting below msg WARNING: Num classes mismatch. Configured: 3, detected by network: 0 could you help me out
HI @h9945394143 ,
This error is from NvDsInferParseCustomResnet() function in /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer_customparser/nvdsinfer_custombboxparser.cpp.
Is your model good to use NvDsInferParseCustomResnet() post-processor? If it’s, you could add some prints to debug why it got “covLayerDims.c == 0”.
i was able to fix it . please close it
