• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.1
• TensorRT Version 8.2 .5
• NVIDIA GPU Driver Version (valid for GPU only) RTX 3080
| NVIDIA-SMI 525.89.02 Driver Version: 525.89.02 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 Off | N/A |
| N/A 49C P8 3W / 150W | 498MiB / 12282MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 557127 C tritonserver 248MiB |
| 0 N/A N/A 620766 C tritonserver 248MiB |
i get the below error on running one of the usecase
Starting pipeline
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
[NvMultiObjectTracker] Loading TRT Engine for tracker ReID…
ERROR: [TRT]: 6: The engine plan file is generated on an incompatible device, expecting compute 8.9 got compute 7.5, please rebuild.
ERROR: [TRT]: 4: [runtime.cpp::deserializeCudaEngine::50] Error Code 4: Internal Error (Engine deserialization failed.)
~~ CLOG[src/modules/ReID/ReID.cpp, loadTRTEngine() @line 445]: Engine build failed
[NvMultiObjectTracker] Load engine failed. Create engine again.
[NvMultiObjectTracker] Begin building engine for tracker ReID…
ERROR: [TRT]: 1: [caskUtils.cpp::trtSmToCask::147] Error Code 1: Internal Error (Unsupported SM: 0x809)
