I got it to work thanks to chat gpt-3, here is how I got it to work if it helps anyone
Code to generate onnx file
import torchvision
import torch
from torch.onnx import OperatorExportTypes
model = torchvision.models.resnet50(weights=torchvision.models.ResNet50_Weights.DEFAULT)
# Export to ONNX
BATCH_SIZE=1
onnx_file = f"resnet50_pytorch_BS{BATCH_SIZE}.onnx"
dummy_input=torch.randn(BATCH_SIZE, 3, 224, 224)
torch.onnx.export(model, dummy_input, onnx_file, verbose=False, input_names=["input"], output_names=["output"], operator_export_type=OperatorExportTypes.ONNX_EXPLICIT_BATCH)
print("Done exporting to ONNX")
Command to export to engine
/usr/src/tensorrt/bin/trtexec --onnx=../../tensorrt/resnet50_pytorch_BS1.onnx --saveEngine=resnet50_engine_pytorch_BS1.engine --explicitBatch --inputIOFormats=fp16:chw --outputIOFormats=fp16:chw --fp16
Configuration file
[property]
gpu-id=0
# 1/255
net-scale-factor=0.0039215697906911373
model-engine-file=resnet50_engine_pytorch_BS1.engine
labelfile-path=../Primary_Detector/label_files/imagenet_labels.txt
force-implicit-batch-dim=1
batch-size=1
network-mode=1
num-detected-classes=4
interval=0
gie-unique-id=1
output-blob-names=fc
classifier-threshold=0.7
is-classifier=1
[class-attrs-all]
pre-cluster-threshold=0.2
eps=0.2
group-threshold=1
# for vehicles
[class-attrs-0]
is-classifier=1
# for bicycles
[class-attrs-1]
is-classifier=1
# for persons
[class-attrs-2]
is-classifier=1
# for roadsigns
[class-attrs-3]
is-classifier=1
Deepstream code
#!/usr/bin/env python3
import argparse
import sys
sys.path.append('/opt/nvidia/deepstream/deepstream-6.1/deepstream_python_apps/apps/')
# Gstreamer
import gi # PyGObject is a Python package that enables links to librarys based on GObjects like GTK , GStreamer , WebKitGTK , GLib , GIO and more.
gi.require_version('Gst', '1.0') # GStreamer
gi.require_version('GstRtspServer', '1.0') # GStreamer rtsp server
from gi.repository import GObject, Gst, GstRtspServer, GLib
# common library
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.FPS import GETFPS
# Python bindings for NVIDIA DeepStream SDK
import pyds
# FPS
fps_streams = {}
getfps_streams = {}
# Ready
ready = False
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
class color:
PURPLE = '\033[95m'
CYAN = '\033[96m'
DARKCYAN = '\033[36m'
BLUE = '\033[94m'
GREEN = '\033[92m'
YELLOW = '\033[93m'
RED = '\033[91m'
BOLD = '\033[1m'
UNDERLINE = '\033[4m'
END = '\033[0m'
def parse_args():
parser = argparse.ArgumentParser(description='RTSP Output Sample Application Help ')
# parser.add_argument("-i", "--input-video", nargs='+', help="List of Path to input H264 elementry stream (required)", required=True)
parser.add_argument("-i", "--input-video", help="Path to v4l2 device path such as /dev/video0", required=True)
parser.add_argument("-o", "--output", default=None, help="Set the output file path ")
parser.add_argument("--input-codec", default="H264", help="Input Codec H264/H265, default=H264", choices=['H264','H265'])
parser.add_argument("--output-codec", default="H264", help="RTSP Streaming Codec H264/H265, default=H264", choices=['H264','H265'])
parser.add_argument("-b", "--bitrate", default=4000000, help="Set the encoding bitrate, default=4000000", type=int)
parser.add_argument("-p", "--port", default=8554, help="Port of RTSP stream, default=8554", type=int)
parser.add_argument("--primary_config_file", default="ds_resnet50.txt", help="Config file, default=ds_resnet50.txt")
# parser.add_argument("--secondary_config_file", default="dstest2_sgie_config.txt", help="Config file, default=dstest2_sgie_config.txt")
# parser.add_argument("--tertiary_config_file", default="dstest2_tgie_config.txt", help="Config file, default=dstest2_tgie_config.txt")
# parser.add_argument("--tracker_config_file", default="dstest2_tracker_config.txt", help="Config file, default=dstest2_tracker_config.txt")
# parser.add_argument("-m", "--meta", default=0, help="set past tracking meta, default=0", type=int)
parser.add_argument("-s", "--stream-name", default="stream1", help="Stream name, default=stream1")
# Check input arguments
if len(sys.argv)==1:
parser.print_help(sys.stderr)
sys.exit(1)
args = parser.parse_args()
batch_size = len(sys.argv)-2
global stream_path
global output_path
global input_codec
global output_codec
global bitrate
global port
global primary_config_file
# global secondary_config_file
# global tertiary_config_file
# global tracker_config_file
# global past_tracking
global stream_name
stream_path = args.input_video
output_path = args.output
input_codec = args.input_codec
output_codec = args.output_codec
bitrate = args.bitrate
port = args.port
primary_config_file = args.primary_config_file
# secondary_config_file = args.secondary_config_file
# tertiary_config_file = args.tertiary_config_file
# tracker_config_file = args.tracker_config_file
# past_tracking = args.meta
stream_name = args.stream_name
return 0
# tiler_sink_pad_buffer_probe will extract metadata received on OSD sink pad
# and update params for drawing rectangle, object information etc.
def tiler_src_pad_buffer_probe(pad,info,u_data):
global ready
if ready == False:
ready = True
print("\n Ready to stream")
getfps_streams["stream{0}".format(0)].update_fps()
fps_streams["stream{0}".format(0)] = getfps_streams["stream{0}".format(0)].get_fps()
frame_number=0
old_frame_number=-1
obj_counter = {
PGIE_CLASS_ID_VEHICLE:0,
PGIE_CLASS_ID_PERSON:0,
PGIE_CLASS_ID_BICYCLE:0,
PGIE_CLASS_ID_ROADSIGN:0
num_rects=0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
frame_number=frame_meta.frame_num
# l_obj=frame_meta.obj_meta_list
num_rects = frame_meta.num_obj_meta
# while l_obj is not None:
# try:
# # Casting l_obj.data to pyds.NvDsObjectMeta
# obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
# except StopIteration:
# break
# obj_counter[obj_meta.class_id] += 1
# try:
# l_obj=l_obj.next
# break
# Acquiring a display meta object. The memory ownership remains in
# the C code so downstream plugins can still access it. Otherwise
# the garbage collector will claim it when this probe function exits.
display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
# Setting display text to be shown on screen
# Note that the pyds module allocates a buffer for the string, and the
# memory will not be claimed by the garbage collector.
# Reading the display_text field here will return the C address of the
# allocated string. Use pyds.get_string() to get the string content.
# py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_VEHICLE], obj_counter[PGIE_CLASS_ID_PERSON])
# py_nvosd_text_params.display_text = f"Yolo:\nstream={frame_meta.pad_index}\nFrame Number={frame_number:04d}\nNumber of Objects={num_rects:03d}\nVehicle_count={obj_counter[PGIE_CLASS_ID_VEHICLE]:03d}\nPerson_count={obj_counter[PGIE_CLASS_ID_PERSON]:04d}\nfps={fps_streams['stream{0}'.format(0)]:.2f}"
py_nvosd_text_params.display_text = f"Yolo:\nstream={frame_meta.pad_index}\n\
Frame Number={frame_number:04d}\nfps={fps_streams['stream{0}'.format(0)]:.2f}\n\
Number of Objects={num_rects:03d}\n"
# Vehicle_count={obj_counter[PGIE_CLASS_ID_VEHICLE]:03d}\n\
# Person_count={obj_counter[PGIE_CLASS_ID_PERSON]:04d}"
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 10;
py_nvosd_text_params.y_offset = 12;
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 0.5)
# send the display overlay to the screen
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
if old_frame_number != frame_number:
# print("Frame Number=", frame_number, "Number of Objects=",num_rects,"Vehicle_count=",obj_counter[PGIE_CLASS_ID_VEHICLE],"Person_count=",obj_counter[PGIE_CLASS_ID_PERSON])
old_frame_number = frame_number
try:
l_frame=l_frame.next
break
return Gst.PadProbeReturn.OK
def cb_newpad(decodebin, decoder_src_pad,data):
caps=decoder_src_pad.get_current_caps()
gststruct=caps.get_structure(0)
gstname=gststruct.get_name()
source_bin=data
features=caps.get_features(0)
# Need to check if the pad created by the decodebin is for video and not
# audio.
print(" In cb_newpad: gstname=",gstname)
if(gstname.find("video")!=-1):
# Link the decodebin pad only if decodebin has picked nvidia
# decoder plugin nvdec_*. We do this by checking if the pad caps contain
# NVMM memory features.
if features.contains("memory:NVMM"):
# Get the source bin ghost pad
bin_ghost_pad=source_bin.get_static_pad("src")
if not bin_ghost_pad.set_target(decoder_src_pad):
sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
else:
sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy,Object,name,user_data):
print(" Decodebin child added:", name)
if(name.find("decodebin") != -1):
Object.connect("child-added",decodebin_child_added,user_data)
def create_source_bin(index,uri):
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name="source-bin-%02d" %index
nbin=Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
uri_decode_bin=Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
print(f"\t\t\tCreating uridecodebin for {bin_name}: {uri}. Source element for reading from the uri")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
uri_decode_bin.set_property("uri",uri)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has beed created by the decodebin
uri_decode_bin.connect("pad-added",cb_newpad,nbin)
uri_decode_bin.connect("child-added",decodebin_child_added,nbin)
# We need to create a ghost pad for the source bin which will act as a proxy
# for the video decoder src pad. The ghost pad will not have a target right
# now. Once the decode bin creates the video decoder and generates the
# cb_newpad callback, we will set the ghost pad target to the video decoder
# src pad.
Gst.Bin.add(nbin,uri_decode_bin)
bin_pad=nbin.add_pad(Gst.GhostPad.new_no_target("src",Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
def osd_sink_pad_buffer_probe(pad,info,u_data):
frame_number=0
# #Intiallizing object counter with 0.
obj_counter = {
num_rects=0
if not gst_buffer:
return
global ready
if ready == False:
ready = True
fps_streams[0].update_fps()
fps = fps_streams[0].get_fps()
try:
# it alone.
break
num_rects = frame_meta.num_obj_meta # Number of rectangles ==> Number of objects
try:
break
try:
l_obj=l_obj.next
break
py_nvosd_text_params.display_text = f"Frame Number={frame_number} fps={fps} Number of Objects={num_rects} Vehicle_count={obj_counter[PGIE_CLASS_ID_VEHICLE]} Person_count={obj_counter[PGIE_CLASS_ID_PERSON]}"
# if obj_counter[PGIE_CLASS_ID_PERSON] > 0:
# print("Person detected")
# else:
# print("No person detected")
py_nvosd_text_params.font_params.font_size = 20
# Using pyds.get_string() to get display_text as string
# print(pyds.get_string(py_nvosd_text_params.display_text))
try:
break
def main(args):
# Init FPS
fps_streams[0] = GETFPS(0)
# Check input arguments (altered using argparse)
if len(args) < 2:
sys.stderr.write("usage: %s -i <uri1> [uri2] ... [uriN]\n" % args[0])
sys.exit(1)
# Get number of video sources
number_sources=len(args)-2
# Init FPS
for i in range(0,len(args)-1):
getfps_streams["stream{0}".format(i)]=GETFPS(i)
fps_streams["stream{0}".format(i)]=0
# Standard GStreamer initialization
gst_status, _ = Gst.init_check(None) # GStreamer initialization
if not gst_status:
sys.stderr.write("Unable to initialize Gst\n")
sys.exit(1)
is_live = True
# Create gstreamer elements
print(" Create gstreamer elements")
# Create Pipeline element that will form a connection of other elements
print("\t Creating Pipeline")
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
# Source element for reading from the file, reads the video data from file
print("\t Creating Source, reads the video data from file")
source = Gst.ElementFactory.make("v4l2src", "usb-cam-source")
if not source:
sys.stderr.write(" Unable to create source \n")
# Create a caps filter, enforces limitations on data (no data modification)
print("\t Creating caps filter, enforces limitations on data (no data modification)")
caps_v4l2src = Gst.ElementFactory.make("capsfilter", "v4l2src_caps")
if not caps_v4l2src:
sys.stderr.write(" Unable to create v4l2src capsfilter \n")
# Adding videoconvert -> nvvideoconvert as not all
# raw formats are supported by nvvideoconvert;
# Say YUYV is unsupported - which is the common
# raw format for many logi usb cams
# In case we have a camera with raw format supported in
# nvvideoconvert, GStreamer plugins' capability negotiation
# shall be intelligent enough to reduce compute by
# videoconvert doing passthrough (TODO we need to confirm this)
# videoconvert to make sure a superset of raw formats are supported
vidconvsrc = Gst.ElementFactory.make("videoconvert", "convertor_src1")
if not vidconvsrc:
sys.stderr.write(" Unable to create videoconvert \n")
# nvvideoconvert to convert incoming raw buffers to NVMM Mem (NvBufSurface API)
print("\t Creating convertor, convert incoming raw buffers to NVMM Mem (NvBufSurface API)")
nvvidconvsrc = Gst.ElementFactory.make("nvvideoconvert", "convertor_src2")
if not nvvidconvsrc:
sys.stderr.write(" Unable to create nvvideoconvert \n")
caps_vidconvsrc = Gst.ElementFactory.make("capsfilter", "nvmm_caps")
if not caps_vidconvsrc:
sys.stderr.write(" Unable to create capsfilter \n")
# Create nvstreammux instance to form batches from one or more sources, batch video streams before sending for AI inference
print("\t Creating nvstreammux instance, batch video streams before sending for AI inference")
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
# Use nvinfer to run inferencing on decoder's output, behaviour of inferencing is set through config file, runs inference using TensorRT
print("\t Creating nvinfer, runs primary inference using TensorRT")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
# Use convertor to convert from NV12 to RGBA as required by nvosd, performs video color format conversion (I420 to RGBA)
print("\t Creating convertor, performs video color format conversion (I420 to RGBA)")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
# Create OSD to draw on the converted RGBA buffer, draw bounding boxes, text and region of interest (ROI) polygons
print("\t Creating OSD, draw bounding boxes, text and region of interest (ROI) polygons")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
# Performs video color format conversion (RGBA to I420)
print("\t Performs video color format conversion (RGBA to I420)")
nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
if not nvvidconv_postosd:
sys.stderr.write(" Unable to create nvvidconv_postosd \n")
caps = Gst.ElementFactory.make("capsfilter", "filter")
caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
# Make the encoder, encodes RAW data in I420 format to H264/H265
if output_codec == "H264":
print("\t Creating H264 Encoder, encodes RAW data in I420 format to H264")
encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
elif output_codec == "H265":
print("\t Creating H265 Encoder, encodes RAW data in I420 format to H265")
encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
if not encoder:
sys.stderr.write(" Unable to create encoder")
encoder.set_property('bitrate', bitrate)
if is_aarch64():
print("\t\t Is aarch64")
encoder.set_property('preset-level', 1)
encoder.set_property('insert-sps-pps', 1)
encoder.set_property('bufapi-version', 1)
if output_path is None:
# Make the payload-encode video into RTP packets, converts H264/H265 encoded Payload to RTP packets (RFC 3984)
print("\t Make the payload-encode video into RTP packets, converts H264/H265 encoded Payload to RTP packets (RFC 3984)")
rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
print("\t Creating H264 rtppay")
rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
print("\t Creating H265 rtppay")
if not rtppay:
sys.stderr.write(" Unable to create rtppay")
# # Make the UDP sink, sends UDP packets to the network. When paired with RTP payloader (Gst-rtph264pay) it can implement RTP streaming
updsink_port_num = 5400
print(f"\t Make the UDP sink in port {updsink_port_num}, sends UDP packets to the network. When paired with RTP payloader (Gst-rtph264pay) it can implement RTP streaming")
sink = Gst.ElementFactory.make("udpsink", "udpsink")
if not sink:
sys.stderr.write(" Unable to create udpsink")
else:
# Since the data format in the input file is elementary h264 or h265 stream, we need a h264parser h265parser, parses the incoming H264/H265 stream
print("\t Creating H264Parser, parses the incoming H264/H265 stream")
codecparse = Gst.ElementFactory.make("h264parse", "h264-parser")
if not codecparse:
sys.stderr.write(" Unable to create h264 parser \n")
# This element merges streams (audio and video) into ISO MPEG-4 (.mp4) files
print("\t Creating mp4mux, merges streams (audio and video) into ISO MPEG-4 (.mp4) files")
mux = Gst.ElementFactory.make("mp4mux", "mux")
if not mux:
sys.stderr.write(" Unable to create mux \n")
# Write incoming data to a file in the local file system
print("\t Creating filesink, write incoming data to a file in the local file system")
sink = Gst.ElementFactory.make("filesink", "filesink")
if not sink:
sys.stderr.write(" Unable to create filesink \n")
sink.set_property('location', output_path)
# Configure sink properties
print(" Configure sink properties")
sink.set_property('host', '224.224.255.255')
sink.set_property('port', updsink_port_num)
sink.set_property('async', False)
sink.set_property('sync', 1)
sink.set_property("qos",0)
# Configure v4l2src properties
print(" Configure v4l2src properties")
print(f" Playing cam {stream_path}")
caps_v4l2src.set_property('caps', Gst.Caps.from_string("video/x-raw, framerate=30/1"))
# Configure caps_vidconvsrc properties
print(" Configure caps_vidconvsrc properties")
caps_vidconvsrc.set_property('caps', Gst.Caps.from_string("video/x-raw(memory:NVMM)"))
# Configure source properties
print(" Configure source properties")
source.set_property('device', stream_path)
# Gel device property of source
print(f" ********************************************************Device property of source: {source.get_property('device')}")
print(f" ********************************************************brightness property of source: {source.get_property('brightness')}")
# Configure streammux properties
print(" Configure streammux properties")
if is_live:
print("\t Atleast one of the sources is live")
streammux.set_property('live-source', 1)
streammux.set_property('width', 1920)
streammux.set_property('height', 1080)
streammux.set_property('batch-size', number_sources)
streammux.set_property('batched-push-timeout', 4000000)
# Configure inference properties
print(" Configure inference properties")
print(f"\t Open {primary_config_file} file\t", end="")
pgie.set_property('config-file-path', primary_config_file)
pgie_batch_size = pgie.get_property("batch-size")
if(pgie_batch_size != number_sources):
print(color.YELLOW + f"WARNING: Overriding infer-config batch-size {pgie_batch_size} with number of sources {number_sources}" + color.END)
pgie.set_property("batch-size",number_sources)
else:
print(color.GREEN + "OK" + color.END)
# print(f"\t Open {secondary_config_file} file\t", end="")
# sgie.set_property('config-file-path', secondary_config_file)
# print(color.GREEN + "OK" + color.END)
# print(f"\t Open {tertiary_config_file} file\t", end="")
# tgie.set_property('config-file-path', tertiary_config_file)
# Adding elements to Pipeline
print(" Adding elements to Pipeline")
pipeline.add(source)
pipeline.add(caps_v4l2src)
pipeline.add(vidconvsrc)
pipeline.add(nvvidconvsrc)
pipeline.add(caps_vidconvsrc)
pipeline.add(streammux)
pipeline.add(pgie)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(nvvidconv_postosd)
pipeline.add(caps)
pipeline.add(encoder)
pipeline.add(sink)
pipeline.add(rtppay)
else:
pipeline.add(codecparse)
pipeline.add(mux)
# Link the elements together
print(" Linking elements in the Pipeline")
srcpad = caps_vidconvsrc.get_static_pad("src")
if not srcpad:
sys.stderr.write(" Unable to get source pad of decoder \n")
sinkpad = streammux.get_request_pad("sink_0")
if not sinkpad:
sys.stderr.write(" Unable to get the sink pad of streammux \n")
source.link(caps_v4l2src) # source-capsfilter
caps_v4l2src.link(vidconvsrc) # capsfilter-videoconvert
vidconvsrc.link(nvvidconvsrc) # videoconvert-nvvideoconvert
nvvidconvsrc.link(caps_vidconvsrc) # nvvideoconvert-capsfilter
srcpad.link(sinkpad) # capsfilter-streammux
streammux.link(pgie) # streammux-pgie
pgie.link(nvvidconv) # pgie-nvvidconv
nvvidconv.link(nvosd) # nvvidconv-nvosd
nvosd.link(nvvidconv_postosd) # nvosd-nvvidconv_postosd
nvvidconv_postosd.link(caps) # nvvidconv_postosd-caps
caps.link(encoder) # caps-encoder
encoder.link(rtppay) # encoder-rtppay
rtppay.link(sink) # rtppay-sink
else:
encoder.link(codecparse)
codecparse.link(mux)
mux.link(sink)
# create an event loop and feed gstreamer bus mesages to it
print(" Creating an event loop and feed gstreamer bus mesages to it")
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect ("message", bus_call, loop)
# Configure RTSP server
print(" Configure RTSP port")
server = GstRtspServer.RTSPServer.new()
server.props.service = f"{port}"
server.attach(None)
factory = GstRtspServer.RTSPMediaFactory.new()
factory.set_launch( f"( udpsrc name=pay0 port={updsink_port_num} buffer-size=524288 caps=\"application/x-rtp, media=video, clock-rate=90000, encoding-name=(string){output_codec}, payload=96 \" )")
factory.set_shared(True)
server.get_mount_points().add_factory(f"/{stream_name}", factory)
print("\t Launched RTSP Streaming at " + color.UNDERLINE + color.GREEN + f"rtsp://localhost:{port}/{stream_name}" + color.END)
# list of sources
print(f" Video sources ({number_sources}):")
for i, source in enumerate(args):
if (i > 1):
print(f"\t {i-1}: {source}")
# Lets add probe to get informed of the meta data generated, we add probe to
# the sink pad of the osd element, since by that time, the buffer would have
# had got all the metadata.
print(" Get metadata from OSD element")
print("\t Get sink of OSD element")
osdsinkpad = nvosd.get_static_pad("sink")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
print("\t Get probe to get informed of the meta data generated")
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
# Starting pipeline, start play back and listed to events
print(" Starting pipeline \n")
pipeline.set_state(Gst.State.PLAYING)
print(" Press Ctrl+C to stop the pipeline \n")
print(f"pgie:\n\
\t Gst-nvinfer Property Group Supported Keys:\n\
\t Gst-nvinfer Class-attributes Group Supported Keys:\n\
\t Gst-nvinfer Gst Properties:\n\
\t\t config-file-path: {pgie.get_property('config-file-path')},\n\
\t\t process-mode: {pgie.get_property('process-mode')},\n\
\t\t unique-id: {pgie.get_property('unique-id')},\n\
\t\t infer-on-gie-id: {pgie.get_property('infer-on-gie-id')},\n\
\t\t filter-out-class-ids: {pgie.get_property('filter-out-class-ids')},\n\
\t\t model-engine-file: {pgie.get_property('model-engine-file')},\n\
\t\t batch-size: {pgie.get_property('batch-size')},\n\
\t\t interval: {pgie.get_property('interval')},\n\
\t\t gpu-id: {pgie.get_property('gpu-id')},\n\
\t\t raw-output-file-write: {pgie.get_property('raw-output-file-write')},\n\
\t\t raw-output-generated-callback: {pgie.get_property('raw-output-generated-callback')},\n\
\t\t raw-output-generated-userdata: {pgie.get_property('raw-output-generated-userdata')},\n\
\t\t output-tensor-meta: {pgie.get_property('output-tensor-meta')},\n\
\t\t output-instance-mask: {pgie.get_property('output-instance-mask')},\n\
\t\t input-tensor-meta: {pgie.get_property('input-tensor-meta')},\n\
# \t\t num-detected-classes: {pgie.get_property('num-detected-classes')}\n\
# \t\t net-scale-factor: {pgie.get_property('net-scale-factor')}\n\
# operate-on-class-ids: {pgie.get_property('operate-on-class-ids')},\n\
try:
loop.run()
except:
pass
# cleanup
pipeline.set_state(Gst.State.NULL)
if __name__ == '__main__':
parse_args()
sys.exit(main(sys.argv))
