• 3060
• DeepStream Version 6.4
• Bug
For a deepstream python application, I use the config_tracker_NvDCF_accuracy tracker.
Here’s the config file used:
%YAML:1.0
# Copyright (c) 2021, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
BaseConfig:
minDetectorConfidence: 0.1894 # If the confidence of a detector bbox is lower than this, then it won't be considered for tracking
TargetManagement:
enableBboxUnClipping: 1 # In case the bbox is likely to be clipped by image border, unclip bbox
preserveStreamUpdateOrder: 0 # When assigning new target ids, preserve input streams' order to keep target ids in a deterministic order over multuple runs
maxTargetsPerStream: 150 # Max number of targets to track per stream. Recommended to set >10. Note: this value should account for the targets being tracked in shadow mode as well. Max value depends on the GPU memory capacity
# [Creation & Termination Policy]
minIouDiff4NewTarget: 0.3686 # If the IOU between the newly detected object and any of the existing targets is higher than this threshold, this newly detected object will be discarded.
minTrackerConfidence: 0.1513 # If the confidence of an object tracker is lower than this on the fly, then it will be tracked in shadow mode. Valid Range: [0.0, 1.0]
probationAge: 2 # If the target's age exceeds this, the target will be considered to be valid.
maxShadowTrackingAge: 42 # Max length of shadow tracking. If the shadowTrackingAge exceeds this limit, the tracker will be terminated.
earlyTerminationAge: 1 # If the shadowTrackingAge reaches this threshold while in TENTATIVE period, the target will be terminated prematurely.
TrajectoryManagement:
useUniqueID: 0 # Use 64-bit long Unique ID when assignining tracker ID. Default is [true]
enableReAssoc: 1 # Enable Re-Assoc
# [Re-Assoc Metric: Thresholds for valid candidates]
minMatchingScore4Overall: 0.6622 # min matching score for overall
minTrackletMatchingScore: 0.2940 # min tracklet similarity score for re-assoc
minMatchingScore4ReidSimilarity: 0.0771 # min reid similarity score for re-assoc
# [Re-Assoc Metric: Weights]
matchingScoreWeight4TrackletSimilarity: 0.7981 # weight for tracklet similarity score
matchingScoreWeight4ReidSimilarity: 0.3848 # weight for reid similarity score
# [Re-Assoc: Motion-based]
minTrajectoryLength4Projection: 34 # min trajectory length required to make projected trajectory
prepLength4TrajectoryProjection: 58 # the length of the trajectory during which the state estimator is updated to make projections
trajectoryProjectionLength: 33 # the length of the projected trajectory
maxAngle4TrackletMatching: 67 # max angle difference for tracklet matching [degree]
minSpeedSimilarity4TrackletMatching: 0.0574 # min speed similarity for tracklet matching
minBboxSizeSimilarity4TrackletMatching: 0.1013 # min bbox size similarity for tracklet matching
maxTrackletMatchingTimeSearchRange: 27 # the search space in time for max tracklet similarity
trajectoryProjectionProcessNoiseScale: 0.0100 # trajectory projector's process noise scale w.r.t. state estimator
trajectoryProjectionMeasurementNoiseScale: 100 # trajectory projector's measurement noise scale w.r.t. state estimator
trackletSpacialSearchRegionScale: 0.0100 # the search region scale for peer tracklet
# [Re-Assoc: Reid based. Reid model params are set in ReID section]
reidExtractionInterval: 8 # frame interval to extract reid features per target
DataAssociator:
dataAssociatorType: 0 # the type of data associator among { DEFAULT= 0 }
associationMatcherType: 1 # the type of matching algorithm among { GREEDY=0, CASCADED=1 }
checkClassMatch: 1 # If checked, only the same-class objects are associated with each other. Default: true
# [Association Metric: Thresholds for valid candidates]
minMatchingScore4Overall: 0.0222 # Min total score
minMatchingScore4SizeSimilarity: 0.3552 # Min bbox size similarity score
minMatchingScore4Iou: 0.0548 # Min IOU score
minMatchingScore4VisualSimilarity: 0.5043 # Min visual similarity score
# [Association Metric: Weights]
matchingScoreWeight4VisualSimilarity: 0.3951 # Weight for the visual similarity (in terms of correlation response ratio)
matchingScoreWeight4SizeSimilarity: 0.6003 # Weight for the Size-similarity score
matchingScoreWeight4Iou: 0.4033 # Weight for the IOU score
# [Association Metric: Tentative detections] only uses iou similarity for tentative detections
tentativeDetectorConfidence: 0.1024 # If a detection's confidence is lower than this but higher than minDetectorConfidence, then it's considered as a tentative detection
minMatchingScore4TentativeIou: 0.2852 # Min iou threshold to match targets and tentative detection
StateEstimator:
stateEstimatorType: 1 # the type of state estimator among { DUMMY=0, SIMPLE=1, REGULAR=2 }
# [Dynamics Modeling]
processNoiseVar4Loc: 6810.8668 # Process noise variance for bbox center
processNoiseVar4Size: 1541.8647 # Process noise variance for bbox size
processNoiseVar4Vel: 1348.4874 # Process noise variance for velocity
measurementNoiseVar4Detector: 100.0000 # Measurement noise variance for detector's detection
measurementNoiseVar4Tracker: 293.3238 # Measurement noise variance for tracker's localization
VisualTracker:
visualTrackerType: 1 # the type of visual tracker among { DUMMY=0, NvDCF=1 }
# [NvDCF: Feature Extraction]
useColorNames: 1 # Use ColorNames feature
useHog: 1 # Use Histogram-of-Oriented-Gradient (HOG) feature
featureImgSizeLevel: 3 # Size of a feature image. Valid range: {1, 2, 3, 4, 5}, from the smallest to the largest
featureFocusOffsetFactor_y: -0.1054 # The offset for the center of hanning window relative to the feature height. The center of hanning window would move by (featureFocusOffsetFactor_y*featureMatSize.height) in vertical direction
# [NvDCF: Correlation Filter]
filterLr: 0.0767 # learning rate for DCF filter in exponential moving average. Valid Range: [0.0, 1.0]
filterChannelWeightsLr: 0.0339 # learning rate for the channel weights among feature channels. Valid Range: [0.0, 1.0]
gaussianSigma: 0.5687 # Standard deviation for Gaussian for desired response when creating DCF filter [pixels]
ReID:
reidType: 2 # The type of reid among { DUMMY=0, NvDEEPSORT=1, Reid based reassoc=2, both NvDEEPSORT and reid based reassoc=3}
# [Reid Network Info]
batchSize: 100 # Batch size of reid network
workspaceSize: 1000 # Workspace size to be used by reid engine, in MB
reidFeatureSize: 256 # Size of reid feature
reidHistorySize: 100 # Max number of reid features kept for one object
inferDims: [3, 256, 128] # Reid network input dimension CHW or HWC based on inputOrder
networkMode: 1 # Reid network inference precision mode among {fp32=0, fp16=1, int8=2 }
# [Input Preprocessing]
inputOrder: 0 # Reid network input order among { NCHW=0, NHWC=1 }. Batch will be converted to the specified order before reid input.
colorFormat: 0 # Reid network input color format among {RGB=0, BGR=1 }. Batch will be converted to the specified color before reid input.
offsets: [123.6750, 116.2800, 103.5300] # Array of values to be subtracted from each input channel, with length equal to number of channels
netScaleFactor: 0.01735207 # Scaling factor for reid network input after substracting offsets
keepAspc: 1 # Whether to keep aspc ratio when resizing input objects for reid
# [Output Postprocessing]
addFeatureNormalization: 1 # If reid feature is not normalized in network, adding normalization on output so each reid feature has l2 norm equal to 1
minVisibility4GalleryUpdate: 0.6 # Add ReID embedding to the gallery only if the visibility is not lower than this
# [Paths and Names]
onnxFile: "/opt/nvidia/deepstream/deepstream/deepstreamInterface/models/resnet50_market1501_aicity156.onnx"
modelEngineFile: "/opt/nvidia/deepstream/deepstream/deepstreamInterface/models/resnet50_market1501_aicity156.onnx_b100_gpu0_fp16.engine" # Engine file path
As you can see, I’ve just modified the end of the file to use the re-identification model provided at the following address (onnx):
When I start my pipeline, the engine is well built and my pipeline runs smoothly.
However, if the engine file (previously built, so no need to build the engine again) is loaded by the pipeline, I get an error :
deepstream-1 | gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
deepstream-1 | [NvMultiObjectTracker] Loading TRT Engine for tracker ReID...
deepstream-1 | [NvMultiObjectTracker] Loading Complete!
deepstream-1 | terminate called after throwing an instance of 'nvinfer1::APIUsageError'
deepstream-1 | what(): Parameter check failed at: runtime/rt/runtime.cpp::~Runtime::346, condition: mEngineCounter.use_count() == 1. Destroying a runtime before destroying deserialized engines created by the runtime leads to undefined behavior.
deepstream-1 |
deepstream-1 exited with code 139
This error doesn’t seem to prevent the pipeline from starting up for the sample:
/opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-test2
But this seems to be a problem when using python.
Thanks for your help
