AMD64 with Nvidia L4 gpu
7.0
TensorRT v8601
driver version 535.183.06
NvDeepSort causes segmentation fault on loading the the engine file.
the engine is built at first runtime from the tao model file provided by Nvidia, i.e.
resnet50_market1501.etlt
this results in an engine file:
resnet50_market1501.etlt_b100_gpu0_int8.engine
which I can load with trxtexec just fine.
/usr/src/tensorrt/bin/trtexec --loadEngine=models/NvDeepsort/resnet50_market1501.etlt_b100_gpu0_int8.engine
executes without errors, and runs & benchmarks the REID model.
When I run my pipeline for the first time, without the engine file, it is built at runtime and the pipeline subseuqently executes without errors.
With the engine file already generated, when I run the pipeline , it just aborts after loading:
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Loading TRT Engine for tracker ReID...
[NvMultiObjectTracker] Loading Complete!
Aborted (core dumped)
I believe this error is coming from the nvtracker module, configured to run NvDeepSort
Tracker highlevel config:
[tracker]
tracker-width=640
tracker-height=384
gpu-id=0
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file=/opt/deepstream-pose-estimation/config/config_tracker_NvDeepSORT.yml
compute-hw=1
the yml config:
BaseConfig:
minDetectorConfidence: 0.0762 # If the confidence of a detector bbox is lower than this, then it won’t be considered for tracking
TargetManagement:
preserveStreamUpdateOrder: 0 # When assigning new target ids, preserve input streams’ order to keep target ids in a deterministic order over multuple runs
maxTargetsPerStream: 150 # Max number of targets to track per stream. Recommended to set >10. Note: this value should account for the targets being tracked in shadow mode as well. M
ax value depends on the GPU memory capacity
[Creation & Termination Policy]
minIouDiff4NewTarget: 0.85 #0.9847 # If the IOU between the newly detected object and any of the existing targets is higher than this threshold, this newly detected object will be d
iscarded.
minTrackerConfidence: 0.3 #0.4314 # If the confidence of an object tracker is lower than this on the fly, then it will be tracked in shadow mode. Valid Range: [0.0, 1.0]
probationAge: 2 # If the target’s age exceeds this, the target will be considered to be valid.
maxShadowTrackingAge: 300 #68 # Max length of shadow tracking. If the shadowTrackingAge exceeds this limit, the tracker will be terminated.
earlyTerminationAge: 3 #1 # If the shadowTrackingAge reaches this threshold while in TENTATIVE period, the the target will be terminated prematurely.
TrajectoryManagement:
useUniqueID: 0 # Use 64-bit long Unique ID when assignining tracker ID.
DataAssociator:
dataAssociatorType: 0 # the type of data associator among { DEFAULT= 0 }
associationMatcherType: 1 # the type of matching algorithm among { GREEDY=0, CASCADED=1 }
checkClassMatch: 1 # If checked, only the same-class objects are associated with each other. Default: true
[Association Metric: Mahalanobis distance threshold (refer to DeepSORT paper) ]
thresholdMahalanobis: 1500 #12.1875 # Threshold of Mahalanobis distance. A detection and a target are not matched if their distance is larger than the threshold.
[Association Metric: Thresholds for valid candidates]
minMatchingScore4Overall: 0.1794 # Min total score
minMatchingScore4SizeSimilarity: 0.3291 # Min bbox size similarity score
minMatchingScore4Iou: 0.2364 # Min IOU score
minMatchingScore4ReidSimilarity: 0.5 #0.7505 # Min reid similarity score
[Association Metric: Weights for valid candidates]
matchingScoreWeight4SizeSimilarity: 0.2 #0.7178 # Weight for the Size-similarity score
matchingScoreWeight4Iou: 0.5 #0.4551 # Weight for the IOU score
matchingScoreWeight4ReidSimilarity: 0.6 #0.3197 # Weight for the reid similarity
[Association Metric: Tentative detections] only uses iou similarity for tentative detections
tentativeDetectorConfidence: 0.2479 # If a detection’s confidence is lower than this but higher than minDetectorConfidence, then it’s considered as a tentative detection
minMatchingScore4TentativeIou: 0.2376 # Min iou threshold to match targets and tentative detection
StateEstimator:
stateEstimatorType: 2 # the type of state estimator among { DUMMY=0, SIMPLE=1, REGULAR=2 }
[Dynamics Modeling]
noiseWeightVar4Loc: 0.0503 # weight of process and measurement noise for bbox center; if set, location noise will be proportional to box height
noiseWeightVar4Vel: 0.0037 # weight of process and measurement noise for velocity; if set, velocity noise will be proportional to box height
useAspectRatio: 1 # use aspect ratio in Kalman filter’s observation
ReID:
reidType: 1 # The type of reid among { DUMMY=0, DEEP=1 }
[Reid Network Info]
batchSize: 100 # Batch size of reid network
workspaceSize: 1000 # Workspace size to be used by reid engine, in MB
reidFeatureSize: 256 # Size of reid feature
reidHistorySize: 200 #100 # Max number of reid features kept for one object
inferDims: [3, 256, 128] # Reid network input dimension CHW or HWC based on inputOrder
networkMode: 2 # Reid network inference precision mode among {fp32=0, fp16=1, int8=2 }
[Input Preprocessing]
inputOrder: 0 # Reid network input order among { NCHW=0, NHWC=1 }. Batch will be converted to the specified order before reid input.
colorFormat: 0 # Reid network input color format among {RGB=0, BGR=1 }. Batch will be converted to the specified color before reid input.
offsets: [123.6750, 116.2800, 103.5300] # Array of values to be subtracted from each input channel, with length equal to number of channels
netScaleFactor: 0.01735207 # Scaling factor for reid network input after substracting offsets
keepAspc: 1 # Whether to keep aspc ratio when resizing input objects for reid
[Output Postprocessing]
addFeatureNormalization: 1 # If reid feature is not normalized in network, adding normalization on output so each reid feature has l2 norm equal to 1
[Paths and Names]
tltEncodedModel: “/opt/deepstream-pose-estimation/models/NvDeepsort/resnet50_market1501.etlt” # NVIDIA TAO model path
tltModelKey: “nvidia_tao” # NVIDIA TAO model key
modelEngineFile: “/opt/deepstream-pose-estimation/models/NvDeepsort/resnet50_market1501.etlt_b100_gpu0_int8.engine”
Engine file path
#enable-dla: 1
#use-dla-core: 0
