• Hardware Platform (Jetson / GPU) - nvcr.io/nvidia/deepstream:6.1.1-devel
• DeepStream Version - 6.1.1
• TensorRT Version - 8.4.1
• NVIDIA GPU Driver Version (valid for GPU only) - 520.61.05
• Issue Type( questions, bugs)
• How to reproduce the issue ? run deepstream-test1 app with dstest1_config.yml
root@tensorbook:/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test1# ./deepstream-test1-app dstest1_config.yml
Using file: dstest1_config.yml
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1482 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.1/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:03.775129855 337 0x55b4b82d28c0 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.1/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:03.776150111 337 0x55b4b82d28c0 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.1/sources/apps/sample_apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:03.776176758 337 0x55b4b82d28c0 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
WARNING: [TRT]: GPU error during getBestTactic: conv1 + bn_conv1 + activation_1/Relu : invalid configuration argument
[ ERROR: CUDA Runtime ] invalid configuration argument
ERROR: [TRT]: 1: [caskBuilderUtils.h::transform::204] Error Code 1: Cask (CASK Transform Weights Failed)
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1119 Build engine failed from config file
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:811 failed to build trt engine.
0:00:12.144044735 337 0x55b4b82d28c0 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1943> [UID = 1]: build engine file failed
0:00:12.145486187 337 0x55b4b82d28c0 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2029> [UID = 1]: build backend context failed
0:00:12.145510831 337 0x55b4b82d28c0 ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1266> [UID = 1]: generate backend failed, check config file settings
0:00:12.145524724 337 0x55b4b82d28c0 WARN nvinfer gstnvinfer.cpp:846:gst_nvinfer_start:<primary-nvinference-engine> error: Failed to create NvDsInferContext instance
0:00:12.145528266 337 0x55b4b82d28c0 WARN nvinfer gstnvinfer.cpp:846:gst_nvinfer_start:<primary-nvinference-engine> error: Config file path: dstest1_pgie_config.yml, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Running...
ERROR from element primary-nvinference-engine: Failed to create NvDsInferContext instance
Error details: gstnvinfer.cpp(846): gst_nvinfer_start (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Deleting pipeline
