Is bug ?deepstream docker image 's app run error:Error Code 1: Cudnn (Could not initialize cudnn, please check cudnn installation.)
RTX 3090
• DeepStream Version
DEEP Stream 6
• TensorRT Version
Driver Version: 470.82.01 CUDA Version: 11.4
is bug?
I get deepstream docker image like this:
docker pull nvcr.io/nvidia/deepstream:6.0-devel
sudo docker run -p 9522:22 --restart=always --name deepstream6dev -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=:0 -v /home/incar/data:/data -v /home/incar/source:/source --gpus all -it nvcr.io/nvidia/deepstream:6.0-devel
and I get a error when run command in docker:
root@0ff4a9a48122:/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app# deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
libEGL warning: DRI2: failed to authenticate
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1484 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine open error
0:00:01.704163315 130 0x7fa48c002270 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed
0:00:01.704219274 130 0x7fa48c002270 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine failed, try rebuild
0:00:01.704231791 130 0x7fa48c002270 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
ERROR: [TRT]: 1: [executionResources.cpp::setTacticSources::146] Error Code 1: Cudnn (Could not initialize cudnn, please check cudnn installation.)
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1119 Build engine failed from config file
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:811 failed to build trt engine.
0:00:03.957923451 130 0x7fa48c002270 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:03.958191280 130 0x7fa48c002270 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:03.958213570 130 0x7fa48c002270 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:03.958253365 130 0x7fa48c002270 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:03.958260502 130 0x7fa48c002270 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Config file path: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_infer_primary.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: main:658: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
This is a set up issue. Please make sure the GPU driver and CUDA is correct with your host machine.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html#platform-and-os-compatibility
my host machine install cuda_11.4.3_470.82.01_linux.run and cudnn-11.4-linux-x64-v8.2.4.15.tgz and I think is ok for your guide. could it have a independent cuda version and cudnn version for docker container ?
Please make sure NVIDIA driver 470.63.01 or above is installed correctly in your host.
