• Hardware Platform (Jetson / GPU) GPU- Quadro p4000
• DeepStream Version deepstream 5.0
• TensorRT Version7.0.0-1+cuda10.2
**• NVIDIA GPU Driver Version (valid for GPU only)**450.80.02
**• Issue Type( questions, new requirements, bugs)**bug
For this, I am working within the dockerized instance of deepstream complete with the demos. I am attempting to run deepstream test1 on one of the sample streams by running the following command:
./deepstream-test1-app …/…/…/…/samples/streams/sample_720p.h264
Doing so produces the following results
Now playing: …/…/…/…/samples/streams/sample_720p.h264
libEGL warning: DRI2: failed to authenticate
WARNING: …/nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
0:00:01.340717121 432 0x55d2f8e95b20 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x400:00:01.340846520 432 0x55d2f8e95b20 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:01.341982330 432 0x55d2f8e95b20 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Running…
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
Frame Number = 0 Number of objects = 6 Vehicle Count = 4 Person Count = 2
0:00:01.622897927 432 0x55d2ef6bc140 WARN nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:01.622916845 432 0x55d2ef6bc140 WARN nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop: error: streaming stopped, reason not-negotiated (-4)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(1975): gst_nvinfer_output_loop (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Frame Number = 1 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 2 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 3 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 4 Number of objects = 5 Vehicle Count = 3 Person Count = 2
Frame Number = 5 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 6 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Deleting pipeline
I see a black screen flash for a moment, before vanishing. I believe the issue is with the CuGraphics error as on a seperate machine, I can run this without any issue. I am running on Ubuntu 18.04.5 and have tried installing the 450, 455, and 460 drivers through the Ubuntu software manager to get the same issue.
Here is the current output of nvidia-smi
| NVIDIA-SMI 450.80.02 Driver Version: 450.80.02 CUDA Version: 11.0 |
| | | MIG M. |
| 0 Quadro P4000 Off | 00000000:3B:00.0 Off | N/A |
| 46% 26C P8 5W / 105W | 7MiB / 8119MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
Any help would be appreciated, I’m at a loss for steps to take to get this working on the new machine.
