**• Hardware Platform (Jetson / GPU)------GPU:GTX A4000
**• DeepStream Version-----5.1
**• TensorRT Version7.2
**• NVIDIA GPU Driver Version (valid for GPU only)------465.31
HI, guys,
I am attempting to run an instance of deepstream demo on my server under ubuntu18.04 with the following command:
./deepstream-test1-app …/…/…/…/samples/streams/sample_720p.h264
Now playing: /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264
0:00:04.963320321 44511 0x563706b85530 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:04.963485089 44511 0x563706b85530 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:04.964758517 44511 0x563706b85530 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Running…
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
Frame Number = 0 Number of objects = 6 Vehicle Count = 4 Person Count = 2
0:00:05.448249243 44511 0x563705771940 WARN nvinfer gstnvinfer.cpp:1984:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:05.448269796 44511 0x563705771940 WARN nvinfer gstnvinfer.cpp:1984:gst_nvinfer_output_loop: error: streaming stopped, reason not-negotiated (-4)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(1984): gst_nvinfer_output_loop (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Frame Number = 1 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 2 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 3 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 4 Number of objects = 5 Vehicle Count = 3 Person Count = 2
Frame Number = 5 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 6 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Deleting pipeline
nvidia-smi
Fri Oct 15 11:41:53 2021
| NVIDIA-SMI 465.31 Driver Version: 465.31 CUDA Version: 11.3 |
| | | MIG M. |
| 0 NVIDIA RTX A4000 Off | 00000000:04:00.0 Off | Off |
| 30% 43C P0 34W / 140W | 0MiB / 16117MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
deepstream-app --version-all
deepstream-app version 5.1.0
DeepStreamSDK 5.1.0
CUDA Driver Version: 11.3
CUDA Runtime Version: 11.1
TensorRT Version: 7.2
cuDNN Version: 8.1
libNVWarp360 Version: 2.0.1d3
