Error with nveglglessink : cuGraphicsGLRegisterBuffer failed with error(304) gst_eglglessink_cuda_init texture = 1
Here my setup :
• Hardware Platform (Jetson / GPU) : Geforce GTX 1060 mobile
• DeepStream Version : 6.1
• TensorRT Version : 8.4.3.1
Cuda version : 11.7
• NVIDIA GPU Driver Version (valid for GPU only) : 515.65.01
I use a custom version of deepstream-test-3 with python 3.8
The issue :
After reinstalling drivers because i had issues, and i reinstalled cuda tensorrt and Deepstream but now i have a bug i never saw before (I could see this because i did export GST_DEBUG=3 before running):
I reinstall severals times my drivers,cuda, tensorrt and deepstream using different version but nothing work.
Thanks in advance,
Pierre Corbani
PS: I saw this topic having the same issue (i don’t have libGLE and libEGL linked with nvidia) but the solution provided doesn’t work for me. Link : cuGraphicsGLRegisterBuffer failed with error(304) gst_eglglessink_cuda_init texture =1
From the description, you used TRT and cuda version not same as
  • CUDA 11.6 Update 1
  • TensorRT 8.2.5.1
    I see you tried different versions, did you try above version?
Yes i tried but i had the same issue, but i just solved this issue with :
sudo prime-select nvidia
Thanks for your time.
