DeepStream 6.2 Run deepstream-test5 error
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• TensorRT Version 8.5.2
• NVIDIA GPU Driver Version (valid for GPU only) 525.116.04
• Issue Type( questions, new requirements, bugs) questions
When I run the deepstream-test5, the following error occurred. How can I resolve it?
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
0:00:03.329929573 461 0x5598679c70c0 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2922:gst_eglglessink_configure_caps:<sink_sub_bin_sink1> Cuda Init failed
0:00:03.329938181 461 0x5598679c70c0 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2933:gst_eglglessink_configure_caps:<sink_sub_bin_sink1> Configuring caps failed
0:00:03.330064415 461 0x5598679c7120 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps:<sink_sub_bin_sink1> Failed to configure caps
0:00:03.330124797 461 0x5598679c7120 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps:<sink_sub_bin_sink1> Failed to configure caps
0:00:03.330129488 461 0x5598679c7120 WARN GST_PADS gstpad.c:4231:gst_pad_peer_query:<sink_sub_bin_cap_filter1:src> could not send sticky events
0:00:03.330234860 461 0x5598679c7120 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps:<sink_sub_bin_sink1> Failed to configure caps
0:00:03.330241326 461 0x5598679c7120 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps:<sink_sub_bin_sink1> Failed to configure caps
0:00:03.330247326 461 0x5598679c7120 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps:<sink_sub_bin_sink1> Failed to configure caps
0:00:03.330252625 461 0x5598679c7120 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps:<sink_sub_bin_sink1> Failed to configure caps
0:00:03.481814481 461 0x5598679c7120 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2978:gst_eglglessink_setcaps:<sink_sub_bin_sink1> Failed to configure caps
WARNING; playback mode used with URI [file:///usr/src/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-test5/configs/…/…/…/…/…/samples/streams/sample_1080p_h264.mp4] not conforming to timestamp format; check README; using system-time
nvstreammux: Successfully handled EOS for source_id=0
0:00:05.611030614 461 0x5598679c6d20 WARN queue gstqueue.c:988:gst_queue_handle_sink_event:<osd_queue> error: Internal data stream error.
0:00:05.611041390 461 0x5598679c6d20 WARN queue gstqueue.c:988:gst_queue_handle_sink_event:<osd_queue> error: streaming stopped, reason not-negotiated (-4)
0:00:05.611168357 461 0x5598679c6d20 WARN nvstreamdemux gstnvstreamdemux.c:520:gst_nvstreamdemux_sink_event: nvstreamdemux srcpad[src_00] EOS pad_push failed; the pad might not be active; EOS will be handled for default behaviour inside nvstreamdemux
ERROR from osd_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:osd_bin/GstQueue:osd_queue:
Quitting
[NvMultiObjectTracker] De-initialized
App run failed
Same as the 291216
