Docker Desktop with WSL 2 backend • DeepStream Version
5.0.0 • JetPack Version (valid for Jetson only) • TensorRT Version
7.0.0-1+cuda10.2 • NVIDIA GPU Driver Version (valid for GPU only)
470.14 • Issue Type( questions, new requirements, bugs)
Bug, Unable to successfully run samples provided in README using eglsink. • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
Step 1: Install “Docker Desktop with WSL 2 backend” and “X server (VcXsrv)” on Window 10 (with Insider Programme). Step 2: Run docker run --gpus all -it -e DISPLAY=192.168.1.100:0.0 -v ~/directory_name/deep_stream:/home/deepstream nvcr.io/nvidia/deepstream:5.0-20.07-samples /bin/bash on elevated PowerShell7. Step 3: Run deepstream-app -c configs/deepstream-app/source4_1080p_dec_infer_resnet_tracker_sgie_tiled_display_int8.txt inside docker container. Step 4: Bug happened where the “XLaunch is blackscreen” and ERROR message: “ERROR from secondary_gie_bin_queue: Internal data stream error.” appeared.
•Debugging Process which had been carried out
Process: Run apt-get install nano and nano configs/deepstream-app/source4_1080p_dec_infer_resnet_tracker_sgie_tiled_display_int8.txt to modify type of [sink0] from Type=2 (EglSink) to Type=1 (FakeSink). Result: The deepstream-app -c configs/deepstream-app/source4_1080p_dec_infer_resnet_tracker_sgie_tiled_display_int8.txt run without any error or bugs.
Process: Run docker run --rm -it -e DISPLAY=192.168.1.100:0.0 aliustaoglu/firefox on elevated PowerShell7. Result: The Firefox installed in the docker run without any error. Desktop display is set into the Docker container.
I am using Docker Desktop on Windows 10 with WSL 2 as backends to run DS5.0. For my Windows 10, I am using NVIDIA GeForce GTX 1660 Ti version 470.14 as my GPU.
Sure. By the way, I would like to show my appreciation for your help by saying Thank you.
This is the error log files with debug level set to 1 by using --gst-debug-level=1.
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
