ERROR: Could not init EGL display connection with ./deepstream-test1-app sample_720p....
Hi all, I am trying to run
GST_DEBUG=4 ./deepstream-test1-app ../../../../samples/streams/sample_720p.h264
from the docker image
nvcr.io/nvidia/deepstream:4.0-19.07
and got the EGL display connection error as bellow:
Error tracelog:
0:00:00.138788622    80 0x55d84bccf800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:160:gst_egl_adaptation_init_display:<nvvideo-renderer> Could not init EGL display connection
0:00:00.138807958    80 0x55d84bccf800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:183:gst_egl_adaptation_init_display:<nvvideo-renderer> EGL call returned error 3000
0:00:00.138816194    80 0x55d84bccf800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:185:gst_egl_adaptation_init_display:<nvvideo-renderer> Couldn't setup window/surface from handle
0:00:00.138823718    80 0x55d84bccf800 ERROR          nveglglessink ext/eglgles/gsteglglessink.c:536:egl_init:<nvvideo-renderer> Couldn't init EGL display
0:00:00.138829990    80 0x55d84bccf800 ERROR          nveglglessink ext/eglgles/gsteglglessink.c:562:egl_init:<nvvideo-renderer> Failed to perform EGL init
0:00:00.138836923    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2961:gst_element_change_state:<nvvideo-renderer> have FAILURE change_state return
0:00:00.138846431    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2549:gst_element_abort_state:<nvvideo-renderer> aborting state from NULL to READY
0:00:00.138860988    80 0x55d84bccf800 INFO              GST_STATES gstbin.c:2970:gst_bin_change_state_func:<dstest1-pipeline> child 'nvvideo-renderer' failed to go to state 2(READY)
0:00:00.138882799    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvideo-renderer> completed state change to NULL
0:00:00.138893249    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nv-onscreendisplay> completed state change to NULL
0:00:00.138902025    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvideo-converter> completed state change to NULL
0:00:00.138911213    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<primary-nvinference-engine> completed state change to NULL
0:00:00.138939486    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<stream-muxer> completed state change to NULL
0:00:00.138956738    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvv4l2-decoder> completed state change to NULL
0:00:00.138966827    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<h264-parser> completed state change to NULL
0:00:00.138977367    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<file-source> completed state change to NULL
0:00:00.138988608    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2961:gst_element_change_state:<dstest1-pipeline> have FAILURE change_state return
0:00:00.138996673    80 0x55d84bccf800 INFO              GST_STATES gstelement.c:2549:gst_element_abort_state:<dstest1-pipeline> aborting state from NULL to PLAYING
Since I don’t have a nvidia display card, I need to change the display to type 1 (FakeSink) or type 3 (File). So, I need to know where to change it?, what is the config file used for the test ./deepstream-test1-app?, I have changed all the below files to type 3 without success (I guess these are applicable only to the deepstream-app sample):
root@73053e8fbdad:~/deepstream_sdk_v4.0_x86_64/samples/configs/deepstream-app#
config_infer_primary.txt
config_infer_primary_nano.txt
config_infer_secondary_carcolor.txt
config_infer_secondary_carmake.txt
config_infer_secondary_vehicletypes.txt
iou_config.txt
source1_usb_dec_infer_resnet_int8.txt
source30_1080p_dec_infer-resnet_tiled_display_int8.txt
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt
Do you run on Jetson platforms or Tesla P4?
Hi, I am running on T4
You can change from deepstream test1 code,
sink = gst_element_factory_make (“nveglglessink”, “nvvideo-renderer”);
change nveglglessink to fakesink
or you can use deepstream-app, the config have the option to change
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
Thanks so much amycao, both tests are working now. There were a bunch numbers hard to interpretate. Can you recommend how to run these tets for better understanding?, and also are there some benchmarks to compare performance running DeepStrem on CPU versus GPU only?; or benchmarks for GPU only at least?; one more, what are the best GPU models to run DeepStream?
https://docs.nvidia.com/metropolis/deepstream/4.0/dev-guide/index.html#page/DeepStream_Development_Guide%2Fdeepstream_performance.html
Here is the performance measured for Deepstream sdk, also the setup configuration.
Thanks amycao, how can I run these samples using vncserver as display type?
You can follow this https://elinux.org/Deepstream/FAQ 5A to setup virtual display
Hi amycao, I have followed the instructions as described in 5A to setup the virtual dispaly; however, I am getting the same error “could not init EGL display connection”. I guess I am missing some step to redirect the output to the virtual display within the docker. Here is what I am doing:
Check the GPU info:
sudo nvidia-xconfig --query-gpu-info
Output:
Number of GPUs: 6
GPU #0:
  UUID      : GPU-fe9bac37-7005-a087-54f8-3a11aade7739
  PCI BusID : PCI:33:0:0
  Number of Display Devices: 0
GPU #1:
  UUID      : GPU-6ae94325-be5a-b35f-cea3-b82539d6b1a9
  PCI BusID : PCI:65:0:0
GPU #2:
  UUID      : GPU-8e12be4d-d335-208a-851a-4e2b89bca8ac
  PCI BusID : PCI:97:0:0
GPU #3:
  UUID      : GPU-2c627dbd-ef94-fc98-60ce-410abda9aae6
  PCI BusID : PCI:129:0:0
GPU #4:
  UUID      : GPU-757aba7a-4abb-aca5-73d0-efe2be4bd0fb
  PCI BusID : PCI:161:0:0
GPU #5:
  UUID      : GPU-da033544-755a-ba50-b5d7-bd62db173118
  PCI BusID : PCI:193:0:0
Install nvidia graphic driver with opengl installed in the local host:
sudo nvidia-xconfig --busid=PCI:33:0:0 --allow-empty-initial-configuration
Output:
Using X configuration file: "/etc/X11/xorg.conf".
Option "AllowEmptyInitialConfiguration" "True" added to Screen "Screen0".
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
New X configuration file written to '/etc/X11/xorg.conf'
Print to stdout the X file configuration:
sudo nvidia-xconfig --tree
Output:
    ServerLayout "Layout0"
        |--> Screen "Screen0"
        |       |--> Monitor "Monitor0"
        |       |       |--> VendorName "Unknown"
        |       |       |--> ModelName "Unknown"
        |       |       |--> HorizSync  28.0-33.0
        |       |       |--> VertRefresh  43.0-72.0
        |       |       |--> Option "DPMS"
        |       |--> Device "Device0"
        |       |       |--> Driver "nvidia"
        |       |       |--> VendorName "NVIDIA Corporation"
        |       |       |--> BusID "PCI:33:0:0"
        |       |--> Option "AllowEmptyInitialConfiguration" "True"
        |       |--> DefaultColorDepth 24
        |--> InputDevice "Keyboard0"
        |       |--> Driver "kbd"
        |       |--> Option "CoreKeyboard"
        |--> InputDevice "Mouse0"
        |       |--> Driver "mouse"
        |       |--> Option "Protocol" "auto"
        |       |--> Option "Device" "/dev/psaux"
        |       |--> Option "Emulate3Buttons" "no"
        |       |--> Option "ZAxisMapping" "4 5"
        |       |--> Option "CorePointer"
Run the deepstream sample from docker image:
nvidia-docker run -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /root nvcr.io/nvidia/deepstream:4.0-19.07
cd /root/deepstream_sdk_v4.0_x86_64/sources/apps/sample_apps/deepstream-test1
make
Error:
0:00:02.475515606    28 0x55fbbedac800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:160:gst_egl_adaptation_init_display:<nvvideo-renderer> Could not init EGL display connection
0:00:02.475534301    28 0x55fbbedac800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:183:gst_egl_adaptation_init_display:<nvvideo-renderer> EGL call returned error 3000
0:00:02.475668704    28 0x55fbbedac800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:185:gst_egl_adaptation_init_display:<nvvideo-renderer> Couldn't setup window/surface from handle
0:00:02.475674725    28 0x55fbbedac800 ERROR          nveglglessink ext/eglgles/gsteglglessink.c:536:egl_init:<nvvideo-renderer> Couldn't init EGL display
0:00:02.475679835    28 0x55fbbedac800 ERROR          nveglglessink ext/eglgles/gsteglglessink.c:562:egl_init:<nvvideo-renderer> Failed to perform EGL init
0:00:02.475687138    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2961:gst_element_change_state:<nvvideo-renderer> have FAILURE change_state return
0:00:02.475809128    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2549:gst_element_abort_state:<nvvideo-renderer> aborting state from NULL to READY
0:00:02.475923012    28 0x55fbbedac800 INFO              GST_STATES gstbin.c:2970:gst_bin_change_state_func:<dstest1-pipeline> child 'nvvideo-renderer' failed to go to state 2(READY)
0:00:02.476054769    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvideo-renderer> completed state change to NULL
0:00:02.476169325    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nv-onscreendisplay> completed state change to NULL
0:00:02.476179454    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvideo-converter> completed state change to NULL
0:00:02.476188651    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<primary-nvinference-engine> completed state change to NULL
0:00:02.476342040    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<stream-muxer> completed state change to NULL
0:00:02.476356186    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvv4l2-decoder> completed state change to NULL
0:00:02.476363800    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<h264-parser> completed state change to NULL
0:00:02.476370994    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<file-source> completed state change to NULL
0:00:02.476381774    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2961:gst_element_change_state:<dstest1-pipeline> have FAILURE change_state return
0:00:02.476388256    28 0x55fbbedac800 INFO              GST_STATES gstelement.c:2549:gst_element_abort_state:<dstest1-pipeline> aborting state from NULL to PLAYING
Can you run xhost + before run docker command, if you run within desktop
or you can give a try by export DISPLAY=:0 before run docker command.
Hi amyco, I have updated to docker CE to 19.03 and run the test again with both options but getting the same error. I am accessing the server remotely through Mobaxterm:
Test #1
xhost +
docker run --gpus all -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /root nvcr.io/nvidia/deepstream:4.0-19.07
make
Error:
0:00:02.469072249    32 0x563c78435800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:160:gst_egl_adaptation_init_display:<nvvideo-renderer> Could not init EGL display connection
0:00:02.469088549    32 0x563c78435800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:183:gst_egl_adaptation_init_display:<nvvideo-renderer> EGL call returned error 3000
0:00:02.469095352    32 0x563c78435800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:185:gst_egl_adaptation_init_display:<nvvideo-renderer> Couldn't setup window/surface from handle
0:00:02.469101664    32 0x563c78435800 ERROR          nveglglessink ext/eglgles/gsteglglessink.c:536:egl_init:<nvvideo-renderer> Couldn't init EGL display
0:00:02.469107986    32 0x563c78435800 ERROR          nveglglessink ext/eglgles/gsteglglessink.c:562:egl_init:<nvvideo-renderer> Failed to perform EGL init
0:00:02.469114769    32 0x563c78435800 INFO              GST_STATES gstelement.c:2961:gst_element_change_state:<nvvideo-renderer> have FAILURE change_state return
0:00:02.469124116    32 0x563c78435800 INFO              GST_STATES gstelement.c:2549:gst_element_abort_state:<nvvideo-renderer> aborting state from NULL to READY
0:00:02.469137381    32 0x563c78435800 INFO              GST_STATES gstbin.c:2970:gst_bin_change_state_func:<dstest1-pipeline> child 'nvvideo-renderer' failed to go to state 2(READY)
0:00:02.469159803    32 0x563c78435800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvideo-renderer> completed state change to NULL
0:00:02.469168850    32 0x563c78435800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nv-onscreendisplay> completed state change to NULL
0:00:02.469177436    32 0x563c78435800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvideo-converter> completed state change to NULL
0:00:02.469185441    32 0x563c78435800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<primary-nvinference-engine> completed state change to NULL
0:00:02.469239583    32 0x563c78435800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<stream-muxer> completed state change to NULL
0:00:02.469341535    32 0x563c78435800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvv4l2-decoder> completed state change to NULL
0:00:02.469353167    32 0x563c78435800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<h264-parser> completed state change to NULL
0:00:02.469363426    32 0x563c78435800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<file-source> completed state change to NULL
0:00:02.469377192    32 0x563c78435800 INFO              GST_STATES gstelement.c:2961:gst_element_change_state:<dstest1-pipeline> have FAILURE change_state return
0:00:02.469388293    32 0x563c78435800 INFO              GST_STATES gstelement.c:2549:gst_element_abort_state:<dstest1-pipeline> aborting state from NULL to PLAYING
Test#2
export DISPLAY=:0
make
Error:
0:00:06.608273502    24 0x56034bc79800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:160:gst_egl_adaptation_init_display:<nvvideo-renderer> Could not init EGL display connection
0:00:06.608291416    24 0x56034bc79800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:183:gst_egl_adaptation_init_display:<nvvideo-renderer> EGL call returned error 3000
0:00:06.608298369    24 0x56034bc79800 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:185:gst_egl_adaptation_init_display:<nvvideo-renderer> Couldn't setup window/surface from handle
0:00:06.608305071    24 0x56034bc79800 ERROR          nveglglessink ext/eglgles/gsteglglessink.c:536:egl_init:<nvvideo-renderer> Couldn't init EGL display
0:00:06.608311203    24 0x56034bc79800 ERROR          nveglglessink ext/eglgles/gsteglglessink.c:562:egl_init:<nvvideo-renderer> Failed to perform EGL init
0:00:06.608318717    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2961:gst_element_change_state:<nvvideo-renderer> have FAILURE change_state return
0:00:06.608328726    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2549:gst_element_abort_state:<nvvideo-renderer> aborting state from NULL to READY
0:00:06.608342081    24 0x56034bc79800 INFO              GST_STATES gstbin.c:2970:gst_bin_change_state_func:<dstest1-pipeline> child 'nvvideo-renderer' failed to go to state 2(READY)
0:00:06.608373500    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvideo-renderer> completed state change to NULL
0:00:06.608388338    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nv-onscreendisplay> completed state change to NULL
0:00:06.608403937    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvideo-converter> completed state change to NULL
0:00:06.608422682    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<primary-nvinference-engine> completed state change to NULL
0:00:06.608466926    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<stream-muxer> completed state change to NULL
0:00:06.608483617    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvv4l2-decoder> completed state change to NULL
0:00:06.608498004    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<h264-parser> completed state change to NULL
0:00:06.608510087    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<file-source> completed state change to NULL
0:00:06.608521829    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2961:gst_element_change_state:<dstest1-pipeline> have FAILURE change_state return
0:00:06.608528331    24 0x56034bc79800 INFO              GST_STATES gstelement.c:2549:gst_element_abort_state:<dstest1-pipeline> aborting state from NULL to PLAYING
Can you paste log /var/log/Xorg.0.log
Hi amycao, where can I find it?, these are the only logs under directory /var/log:
root@7e3565822abe:/var/log# ll
total 800
drwxrwxr-x 1 root syslog   4096 Jul 22 10:50 ./
drwxr-xr-x 1 root root     4096 Jul 22 11:47 ../
-rw-r--r-- 1 root root    18688 Jul 22 11:48 alternatives.log
drwxr-xr-x 1 root root     4096 Jul 22 11:47 apt/
-rw-r--r-- 1 root root    35330 May 15 14:06 bootstrap.log
-rw-rw---- 1 root utmp        0 May 15 14:06 btmp
-rw-r--r-- 1 root root   699554 Jul 22 11:47 dpkg.log
-rw-r--r-- 1 root root     3264 Jul 22 10:50 faillog
-rw-r--r-- 1 root root      351 Jul 22 10:50 fontconfig.log
-rw-rw-r-- 1 root utmp    29784 Jul 22 10:50 lastlog
-rw------- 1 root root     6528 Jul 22 10:50 tallylog
-rw-rw-r-- 1 root utmp        0 May 15 14:06 wtmp
your system environments, not within docker.
I amycao, here is the file generated on Fri Aug 30 11:34:22 2019; even though I ran the test again today, the logfile wasn’t updated. On another hand, I am using Ubuntu 16.04.5 and updated to docker-ce 19.03.
[   124.977]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[   124.977] X Protocol Version 11, Revision 0
[   124.977] Build Operating System: Linux 4.4.0-128-generic x86_64 Ubuntu
[   124.977] Current Operating System: Linux r7425-p4 4.4.0-133-generic #159-Ubuntu SMP Fri Aug 10 07:31:43 UTC 2018 x86_64
[   124.977] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-133-generic root=UUID=bb7ea37f-5331-4fb1-a5ad-e7430a899e55 ro
[   124.977] Build Date: 10 August 2018  09:33:05AM
[   124.977] xorg-server 2:1.18.4-0ubuntu0.8 (For technical support please see http://www.ubuntu.com/support)
[   124.977] Current version of pixman: 0.33.6
[   124.977] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[   124.978] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   124.978] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 30 11:34:22 2019
[   125.016] (==) Using config file: "/etc/X11/xorg.conf"
[   125.016] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   125.052] (==) No Layout section.  Using the first Screen section.
[   125.052] (==) No screen section available. Using defaults.
[   125.052] (**) |-->Screen "Default Screen Section" (0)
[   125.052] (**) |   |-->Monitor "<default monitor>"
[   125.052] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[   125.052] (**) |   |-->Device "Device0"
[   125.052] (**) |   |-->GPUDevice "Device1"
[   125.052] (**) |   |-->GPUDevice "Device2"
[   125.052] (**) |   |-->GPUDevice "Device3"
[   125.052] (**) |   |-->GPUDevice "Device4"
[   125.052] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[   125.052] (==) Automatically adding devices
[   125.052] (==) Automatically enabling devices
[   125.052] (==) Automatically adding GPU devices
[   125.053] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   125.081] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   125.081] 	Entry deleted from font path.
[   125.081] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[   125.081] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[   125.081] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[   125.081] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[   125.081] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[   125.081] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	built-ins
[   125.081] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[   125.081] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[   125.081] (II) Loader magic: 0x5616e0230dc0
[   125.081] (II) Module ABI versions:
[   125.081] 	X.Org ANSI C Emulation: 0.4
[   125.081] 	X.Org Video Driver: 20.0
[   125.081] 	X.Org XInput driver : 22.1
[   125.081] 	X.Org Server Extension : 9.0
[   125.082] (--) using VT number 2
[   125.082] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   125.083] (II) xfree86: Adding drm device (/dev/dri/card0)
[   125.083] (II) xfree86: Adding drm device (/dev/dri/card1)
[   125.083] (II) xfree86: Adding drm device (/dev/dri/card2)
[   125.083] (II) xfree86: Adding drm device (/dev/dri/card3)
[   125.083] (II) xfree86: Adding drm device (/dev/dri/card4)
[   125.083] (II) xfree86: Adding drm device (/dev/dri/card5)
[   125.092] (--) PCI:*(0:3:0:0) 102b:0536:0000:0000 rev 4, Mem @ 0xeb000000/16777216, 0xf9808000/16384, 0xf9000000/8388608
[   125.092] (--) PCI: (0:33:0:0) 10de:1bb3:10de:11d8 rev 161, Mem @ 0xe8000000/16777216, 0x17010000000/268435456, 0x17020000000/33554432
[   125.092] (--) PCI: (0:65:0:0) 10de:1eb8:10de:12a2 rev 161, Mem @ 0xdb000000/16777216, 0x25fa0000000/268435456, 0x25fb0000000/33554432
[   125.092] (--) PCI: (0:97:0:0) 10de:1bb3:10de:11d8 rev 161, Mem @ 0xce000000/16777216, 0x34f30000000/268435456, 0x34f40000000/33554432
[   125.092] (--) PCI: (0:129:0:0) 10de:1bb3:10de:11d8 rev 161, Mem @ 0xc1000000/16777216, 0x43ec0000000/268435456, 0x43ed0000000/33554432
[   125.092] (--) PCI: (0:161:0:0) 10de:1bb3:10de:11d8 rev 161, Mem @ 0xb4000000/16777216, 0x52e50000000/268435456, 0x52e60000000/33554432
[   125.092] (--) PCI: (0:193:0:0) 10de:1bb3:10de:11d8 rev 161, Mem @ 0xa7000000/16777216, 0x61de0000000/268435456, 0x61df0000000/33554432
[   125.092] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[   125.092] (II) "glx" will be loaded by default.
[   125.092] (II) LoadModule: "glx"
[   125.111] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   125.311] (II) Module glx: vendor="X.Org Foundation"
[   125.311] 	compiled for 1.18.4, module version = 1.0.0
[   125.311] 	ABI class: X.Org Server Extension, version 9.0
[   125.311] (==) AIGLX enabled
[   125.311] (II) LoadModule: "nvidia"
[   125.311] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[   125.353] (II) Module nvidia: vendor="NVIDIA Corporation"
[   125.353] 	compiled for 4.0.2, module version = 1.0.0
[   125.353] 	Module class: X.Org Video Driver
[   125.357] (II) NVIDIA dlloader X Driver  418.67  Sat Apr  6 02:51:17 CDT 2019
[   125.357] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[   125.376] (II) Loading sub module "fb"
[   125.376] (II) LoadModule: "fb"
[   125.377] (II) Loading /usr/lib/xorg/modules/libfb.so
[   125.378] (II) Module fb: vendor="X.Org Foundation"
[   125.378] 	compiled for 1.18.4, module version = 1.0.0
[   125.378] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   125.378] (II) Loading sub module "wfb"
[   125.378] (II) LoadModule: "wfb"
[   125.378] (II) Loading /usr/lib/xorg/modules/libwfb.so
[   125.379] (II) Module wfb: vendor="X.Org Foundation"
[   125.380] 	compiled for 1.18.4, module version = 1.0.0
[   125.380] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   125.380] (II) Loading sub module "ramdac"
[   125.380] (II) LoadModule: "ramdac"
[   125.380] (II) Module "ramdac" already built-in
[   125.381] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[   125.381] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[   125.381] (==) NVIDIA(0): RGB weight 888
[   125.381] (==) NVIDIA(0): Default visual is TrueColor
[   125.381] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[   125.381] (**) NVIDIA(0): Enabling 2D acceleration
[   125.381] (II) Loading sub module "glxserver_nvidia"
[   125.381] (II) LoadModule: "glxserver_nvidia"
[   125.381] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglxserver_nvidia.so
[   125.464] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[   125.464] 	compiled for 4.0.2, module version = 1.0.0
[   125.464] 	Module class: X.Org Server Extension
[   125.465] (II) NVIDIA GLX Module  418.67  Sat Apr  6 02:49:59 CDT 2019
[   125.937] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:33:0:0
[   125.937] (--) NVIDIA(0):     DFP-0
[   125.937] (--) NVIDIA(0):     DFP-1
[   125.937] (--) NVIDIA(0):     DFP-2
[   125.937] (--) NVIDIA(0):     DFP-3
[   125.939] (II) NVIDIA(0): NVIDIA GPU Tesla P4 (GP104GL-A) at PCI:33:0:0 (GPU-0)
[   125.939] (--) NVIDIA(0): Memory: 7864320 kBytes
[   125.939] (--) NVIDIA(0): VideoBIOS: 86.04.8c.00.10
[   125.939] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[   125.939] (--) NVIDIA(GPU-0): NVIDIA VGX (DFP-0): connected
[   125.939] (--) NVIDIA(GPU-0): NVIDIA VGX (DFP-0): External TMDS
[   125.939] (WW) NVIDIA(GPU-0): Mode (3840 x 2160) larger than per-head max
[   125.939] (WW) NVIDIA(GPU-0):     resolutionsupported (2560 x 1600)
[   125.939] (WW) NVIDIA(GPU-0): Mode (4096 x 2160) larger than per-head max
[   125.940] (==) NVIDIA(0):
[   125.940] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[   125.940] (==) NVIDIA(0):     will be used as the requested mode.
[   125.940] (II) NVIDIA(0): Validated MetaModes:
[   125.940] (II) NVIDIA(0):     "DFP-0:nvidia-auto-select"
[   125.940] (II) NVIDIA(0): Virtual screen size determined to be 2560 x 1600
[   125.958] (--) NVIDIA(0): DPI set to (92, 101); computed from "UseEdidDpi" X config
[   125.958] (--) NVIDIA(0):     option
[   125.958] (--) Depth 24 pixmap format is 32 bpp
[   126.494] (--) NVIDIA(0): Valid display device(s) on GPU-1 at PCI:65:0:0
[   126.494] (--) NVIDIA(0):     DFP-0
[   126.494] (--) NVIDIA(0):     DFP-1
[   126.494] (--) NVIDIA(0):     DFP-2
[   126.494] (--) NVIDIA(0):     DFP-3
[   126.497] (WW) NVIDIA(GPU-1): Mode (3840 x 2160) larger than per-head max
[   126.497] (WW) NVIDIA(GPU-1):     resolutionsupported (2560 x 1600)
[   126.497] (WW) NVIDIA(GPU-1): Mode (4096 x 2160) larger than per-head max
[   126.497] (--) NVIDIA(GPU-1): NVIDIA VGX (DFP-0): connected
[   126.497] (--) NVIDIA(GPU-1): NVIDIA VGX (DFP-0): External TMDS
[   126.497] (II) NVIDIA(GPU-1): NVIDIA GPU Tesla T4 (TU104GL-A) at PCI:65:0:0 (GPU-1)
[   126.497] (--) NVIDIA(GPU-1): Memory: 15728640 kBytes
[   126.497] (--) NVIDIA(GPU-1): VideoBIOS: 90.04.38.00.04
[   126.497] (II) NVIDIA(GPU-1): Detected PCI Express Link width: 16X
[   126.777] (--) NVIDIA(0): Valid display device(s) on GPU-2 at PCI:97:0:0
[   126.777] (--) NVIDIA(0):     DFP-0
[   126.777] (--) NVIDIA(0):     DFP-1
[   126.777] (--) NVIDIA(0):     DFP-2
[   126.777] (--) NVIDIA(0):     DFP-3
[   126.780] (WW) NVIDIA(GPU-2): Mode (3840 x 2160) larger than per-head max
[   126.780] (WW) NVIDIA(GPU-2):     resolutionsupported (2560 x 1600)
[   126.780] (WW) NVIDIA(GPU-2): Mode (4096 x 2160) larger than per-head max
[   126.780] (--) NVIDIA(GPU-2): NVIDIA VGX (DFP-0): connected
[   126.780] (--) NVIDIA(GPU-2): NVIDIA VGX (DFP-0): External TMDS
[   126.780] (II) NVIDIA(GPU-2): NVIDIA GPU Tesla P4 (GP104GL-A) at PCI:97:0:0 (GPU-2)
[   126.780] (--) NVIDIA(GPU-2): Memory: 7864320 kBytes
[   126.780] (--) NVIDIA(GPU-2): VideoBIOS: 86.04.8c.00.10
[   126.780] (II) NVIDIA(GPU-2): Detected PCI Express Link width: 16X
[   127.102] (--) NVIDIA(0): Valid display device(s) on GPU-3 at PCI:129:0:0
[   127.102] (--) NVIDIA(0):     DFP-0
[   127.102] (--) NVIDIA(0):     DFP-1
[   127.102] (--) NVIDIA(0):     DFP-2
[   127.102] (--) NVIDIA(0):     DFP-3
[   127.105] (WW) NVIDIA(GPU-3): Mode (3840 x 2160) larger than per-head max
[   127.105] (WW) NVIDIA(GPU-3):     resolutionsupported (2560 x 1600)
[   127.105] (WW) NVIDIA(GPU-3): Mode (4096 x 2160) larger than per-head max
[   127.105] (--) NVIDIA(GPU-3): NVIDIA VGX (DFP-0): connected
[   127.105] (--) NVIDIA(GPU-3): NVIDIA VGX (DFP-0): External TMDS
[   127.105] (II) NVIDIA(GPU-3): NVIDIA GPU Tesla P4 (GP104GL-A) at PCI:129:0:0 (GPU-3)
[   127.105] (--) NVIDIA(GPU-3): Memory: 7864320 kBytes
[   127.105] (--) NVIDIA(GPU-3): VideoBIOS: 86.04.8c.00.10
[   127.105] (II) NVIDIA(GPU-3): Detected PCI Express Link width: 16X
[   127.407] (--) NVIDIA(0): Valid display device(s) on GPU-4 at PCI:161:0:0
[   127.407] (--) NVIDIA(0):     DFP-0
[   127.407] (--) NVIDIA(0):     DFP-1
[   127.407] (--) NVIDIA(0):     DFP-2
[   127.407] (--) NVIDIA(0):     DFP-3
[   127.410] (WW) NVIDIA(GPU-4): Mode (3840 x 2160) larger than per-head max
[   127.410] (WW) NVIDIA(GPU-4):     resolutionsupported (2560 x 1600)
[   127.410] (WW) NVIDIA(GPU-4): Mode (4096 x 2160) larger than per-head max
[   127.410] (--) NVIDIA(GPU-4): NVIDIA VGX (DFP-0): connected
[   127.410] (--) NVIDIA(GPU-4): NVIDIA VGX (DFP-0): External TMDS
[   127.410] (II) NVIDIA(GPU-4): NVIDIA GPU Tesla P4 (GP104GL-A) at PCI:161:0:0 (GPU-4)
[   127.410] (--) NVIDIA(GPU-4): Memory: 7864320 kBytes
[   127.410] (--) NVIDIA(GPU-4): VideoBIOS: 86.04.8c.00.10
[   127.410] (II) NVIDIA(GPU-4): Detected PCI Express Link width: 16X
[   127.714] (--) NVIDIA(0): Valid display device(s) on GPU-5 at PCI:193:0:0
[   127.714] (--) NVIDIA(0):     DFP-0
[   127.714] (--) NVIDIA(0):     DFP-1
[   127.714] (--) NVIDIA(0):     DFP-2
[   127.714] (--) NVIDIA(0):     DFP-3
[   127.717] (WW) NVIDIA(GPU-5): Mode (3840 x 2160) larger than per-head max
[   127.717] (WW) NVIDIA(GPU-5):     resolutionsupported (2560 x 1600)
[   127.717] (WW) NVIDIA(GPU-5): Mode (4096 x 2160) larger than per-head max
[   127.717] (--) NVIDIA(GPU-5): NVIDIA VGX (DFP-0): connected
[   127.717] (--) NVIDIA(GPU-5): NVIDIA VGX (DFP-0): External TMDS
[   127.717] (II) NVIDIA(GPU-5): NVIDIA GPU Tesla P4 (GP104GL-A) at PCI:193:0:0 (GPU-5)
[   127.717] (--) NVIDIA(GPU-5): Memory: 7864320 kBytes
[   127.717] (--) NVIDIA(GPU-5): VideoBIOS: 86.04.8c.00.10
[   127.717] (II) NVIDIA(GPU-5): Detected PCI Express Link width: 16X
[   127.721] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[   127.721] (II) NVIDIA:     access.
[   127.760] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[   127.770] (==) NVIDIA(0): Disabling shared memory pixmaps
[   127.770] (==) NVIDIA(0): Backing store enabled
[   127.770] (==) NVIDIA(0): Silken mouse enabled
[   127.771] (==) NVIDIA(0): DPMS enabled
[   127.771] (II) Loading sub module "dri2"
[   127.771] (II) LoadModule: "dri2"
[   127.771] (II) Module "dri2" already built-in
[   127.771] (II) NVIDIA(0): [DRI2] Setup complete
[   127.771] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[   127.771] (--) RandR disabled
[   127.775] (II) SELinux: Disabled on system
[   127.776] (II) Initializing extension GLX
[   127.776] (II) Indirect GLX disabled.
[   128.044] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[   128.044] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   128.044] (II) LoadModule: "evdev"
[   128.044] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[   128.091] (II) Module evdev: vendor="X.Org Foundation"
[   128.091] 	compiled for 1.18.1, module version = 2.10.1
[   128.091] 	Module class: X.Org XInput Driver
[   128.091] 	ABI class: X.Org XInput driver, version 22.1
[   128.092] (II) Using input driver 'evdev' for 'Power Button'
[   128.092] (**) Power Button: always reports core events
[   128.092] (**) evdev: Power Button: Device: "/dev/input/event1"
[   128.092] (--) evdev: Power Button: Vendor 0 Product 0x1
[   128.092] (--) evdev: Power Button: Found keys
[   128.092] (II) evdev: Power Button: Configuring as keyboard
[   128.092] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[   128.092] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[   128.092] (**) Option "xkb_rules" "evdev"
[   128.092] (**) Option "xkb_model" "pc105"
[   128.092] (**) Option "xkb_layout" "us"
[   128.092] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[   128.092] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[   128.092] (**) evdev: Power Button: Device: "/dev/input/event0"
[   128.092] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[   128.092] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[   128.093] (II) config/udev: Adding input device     Multimedia Pro Keyboard (/dev/input/event2)
[   128.093] (**)     Multimedia Pro Keyboard: Applying InputClass "evdev keyboard catchall"
[   128.093] (II) Using input driver 'evdev' for '    Multimedia Pro Keyboard'
[   128.093] (**)     Multimedia Pro Keyboard: always reports core events
[   128.093] (**) evdev:     Multimedia Pro Keyboard: Device: "/dev/input/event2"
[   128.093] (--) evdev:     Multimedia Pro Keyboard: Vendor 0x413c Product 0x2011
[   128.093] (--) evdev:     Multimedia Pro Keyboard: Found keys
[   128.093] (II) evdev:     Multimedia Pro Keyboard: Configuring as keyboard
[   128.093] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:05:00.3/usb1/1-2/1-2.2/1-2.2.1/1-2.2.1:1.0/0003:413C:2011.0001/input/input2/event2"
[   128.093] (II) XINPUT: Adding extended input device "    Multimedia Pro Keyboard" (type: KEYBOARD, id 8)
[   128.093] (**) Option "xkb_rules" "evdev"
[   128.093] (**) Option "xkb_model" "pc105"
[   128.093] (**) Option "xkb_layout" "us"
[   128.094] (II) config/udev: Adding input device     Multimedia Pro Keyboard (/dev/input/event3)
[   128.094] (**)     Multimedia Pro Keyboard: Applying InputClass "evdev keyboard catchall"
[   128.094] (II) Using input driver 'evdev' for '    Multimedia Pro Keyboard'
[   128.094] (**)     Multimedia Pro Keyboard: always reports core events
[   128.094] (**) evdev:     Multimedia Pro Keyboard: Device: "/dev/input/event3"
[   128.094] (--) evdev:     Multimedia Pro Keyboard: Vendor 0x413c Product 0x2011
[   128.094] (--) evdev:     Multimedia Pro Keyboard: Found absolute axes
[   128.094] (II) evdev:     Multimedia Pro Keyboard: Forcing absolute x/y axes to exist.
[   128.094] (--) evdev:     Multimedia Pro Keyboard: Found keys
[   128.094] (II) evdev:     Multimedia Pro Keyboard: Forcing relative x/y axes to exist.
[   128.094] (II) evdev:     Multimedia Pro Keyboard: Configuring as mouse
[   128.094] (II) evdev:     Multimedia Pro Keyboard: Configuring as keyboard
[   128.094] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:05:00.3/usb1/1-2/1-2.2/1-2.2.1/1-2.2.1:1.1/0003:413C:2011.0002/input/input3/event3"
[   128.094] (II) XINPUT: Adding extended input device "    Multimedia Pro Keyboard" (type: KEYBOARD, id 9)
[   128.094] (**) Option "xkb_rules" "evdev"
[   128.094] (**) Option "xkb_model" "pc105"
[   128.094] (**) Option "xkb_layout" "us"
[   128.094] (II) evdev:     Multimedia Pro Keyboard: initialized for absolute axes.
[   128.094] (**)     Multimedia Pro Keyboard: (accel) keeping acceleration scheme 1
[   128.094] (**)     Multimedia Pro Keyboard: (accel) acceleration profile 0
[   128.094] (**)     Multimedia Pro Keyboard: (accel) acceleration factor: 2.000
[   128.094] (**)     Multimedia Pro Keyboard: (accel) acceleration threshold: 4
[   128.095] (II) config/udev: Adding input device     USB Optical Mouse (/dev/input/event4)
[   128.095] (**)     USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[   128.095] (II) Using input driver 'evdev' for '    USB Optical Mouse'
[   128.095] (**)     USB Optical Mouse: always reports core events
[   128.095] (**) evdev:     USB Optical Mouse: Device: "/dev/input/event4"
[   128.148] (--) evdev:     USB Optical Mouse: Vendor 0x413c Product 0x3012
[   128.148] (--) evdev:     USB Optical Mouse: Found 3 mouse buttons
[   128.148] (--) evdev:     USB Optical Mouse: Found scroll wheel(s)
[   128.148] (--) evdev:     USB Optical Mouse: Found relative axes
[   128.148] (--) evdev:     USB Optical Mouse: Found x and y relative axes
[   128.148] (II) evdev:     USB Optical Mouse: Configuring as mouse
[   128.148] (II) evdev:     USB Optical Mouse: Adding scrollwheel support
[   128.148] (**) evdev:     USB Optical Mouse: YAxisMapping: buttons 4 and 5
[   128.148] (**) evdev:     USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[   128.148] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:05:00.3/usb1/1-2/1-2.2/1-2.2.2/1-2.2.2:1.0/0003:413C:3012.0003/input/input4/event4"
[   128.148] (II) XINPUT: Adding extended input device "    USB Optical Mouse" (type: MOUSE, id 10)
[   128.148] (II) evdev:     USB Optical Mouse: initialized for relative axes.
[   128.148] (**)     USB Optical Mouse: (accel) keeping acceleration scheme 1
[   128.148] (**)     USB Optical Mouse: (accel) acceleration profile 0
[   128.148] (**)     USB Optical Mouse: (accel) acceleration factor: 2.000
[   128.148] (**)     USB Optical Mouse: (accel) acceleration threshold: 4
[   128.148] (II) config/udev: Adding input device     USB Optical Mouse (/dev/input/mouse0)
[   128.148] (II) No input driver specified, ignoring this device.
[   128.148] (II) This device may have been added with another device file.
[   143.711] (II) evdev:     USB Optical Mouse: Close
[   143.711] (II) UnloadModule: "evdev"
[   143.711] (II) evdev:     Multimedia Pro Keyboard: Close
[   143.712] (II) UnloadModule: "evdev"
[   143.712] (II) evdev:     Multimedia Pro Keyboard: Close
[   143.712] (II) evdev: Power Button: Close
[   144.975] (II) NVIDIA(GPU-0): Deleting GPU-0
[   144.975] (II) NVIDIA(GPU-1): Renaming GPU-1 to GPU-0
[   144.975] (II) NVIDIA(GPU-2): Renaming GPU-2 to GPU-1
[   144.975] (II) NVIDIA(GPU-3): Renaming GPU-3 to GPU-2
[   144.975] (II) NVIDIA(GPU-4): Renaming GPU-4 to GPU-3
[   144.975] (II) NVIDIA(GPU-5): Renaming GPU-5 to GPU-4
[   144.976] (II) NVIDIA(GPU-0): Deleting GPU-0
[   144.976] (II) NVIDIA(GPU-1): Renaming GPU-1 to GPU-0
[   144.976] (II) NVIDIA(GPU-2): Renaming GPU-2 to GPU-1
[   145.012] (II) Server terminated successfully (0). Closing log file.
seems fine from the log, but from the bottom,
you stop the X service, right?
No, I didn’t stop the X server, also when I ran the test the log file didn’t update, should I delete it and run the test again?
HI
Have you fixed this issue, if not can you try another option, streaming through sink2 RTSPStreaming,
then you can view through vlc, rtsp://ip-of-system-running-ds-app:8554/ds-test
[sink2]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
Hi amycao,
I could run deepstream-app -c source1_usb_dec_infer_resnet_int8.txt via rtsp and fakesink except nveglgssink.
I want to know why? Since I check lsmod | grep nvidia, could see nvidia card. Below command also run successfully
gst-launch-1.0 v4l2src device=/dev/video0 ! “video/x-raw,format=YUY2, width=640, height=480, framerate=25/1” ! videoconvert ! “video/x-raw,format=NV12,width=640, height=480, framerate=25/1” ! nvvideoconvert ! nveglglessink –e
So I think on my container I could use nveglglessink.
Please export DISPLAY=:0 or 1
xrandr (to check if display available)
xhost + (before you run docker)
and add
“-v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY”
in your docker command
