When I run deepstream-test1-app, the error message is like this, it seems that it is related with nveglglessink plugin.
$ ./deepstream-test1-app …/…/…/…/samples/streams/sample_720p.h264
Now playing: …/…/…/…/samples/streams/sample_720p.h264
Creating LL OSD context new
0:00:01.988123903 1267 0xd13f840760 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:03.277800372 1267 0xd13f840760 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): TensorRT was compiled against cuBLAS 10.2.0 but is linked against cuBLAS 10.1.0
0:00:10.123438091 1267 0xd13f840760 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): TensorRT was compiled against cuBLAS 10.2.0 but is linked against cuBLAS 10.1.0
0:00:10.156944340 1267 0xd13f840760 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger: NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/pengxihan/deepstream_sdk_v4.0.1_x86_64/samples/models/Primary_Detector/resnet10.caffemodel_b1_int8.engine
0:00:10.164632026 1267 0xd13f840760 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): TensorRT was compiled against cuBLAS 10.2.0 but is linked against cuBLAS 10.1.0
0:00:10.167444664 1267 0xd13f840760 WARN nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger: NvDsInferContext[UID 1]:log(): TensorRT was compiled against cuBLAS 10.2.0 but is linked against cuBLAS 10.1.0
Running…
cuGraphicsGLRegisterBuffer failed with error(999) gst_eglglessink_cuda_init texture = 1
Entering osd_sink_pad_buffer_probe
frame_meta = 0x7fd708009020
Frame Number = 0 Number of objects = 5 Vehicle Count = 3 Person Count = 2
0:00:10.860135129 1267 0xd13f75b190 WARN nvinfer gstnvinfer.cpp:1830:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:10.860151744 1267 0xd13f75b190 WARN nvinfer gstnvinfer.cpp:1830:gst_nvinfer_output_loop: error: streaming stopped, reason not-negotiated (-4)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(1830): gst_nvinfer_output_loop (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
But I use gst-launch command to test decoder and display, it works well.
$ gst-launch-1.0 filesrc location=/home/pengxihan/deepstream_sdk_v4.0.1_x86_64/samples/streams/sample_720p.h264 ! h264parse ! nvv4l2decoder drop-frame-interval=1 ! nvvideoconvert ! video/x-raw,width=1080,height=720,formate=I420 ! queue ! nveglglessink window-x=0 window-y=0 window-width=1080 window-height=720
