Deepstream FPS issue
• DeepStream Version
• TensorRT Version
Deepstream version 6.1.1 docker container
I am running deepstream_imagedata-multistream app using yolov5l.
Outside the deepstream container in my local we are getting 111 FPS as inferencespeed for one frame.
But in that application with one source video its showing only 33 FPS in deepstream.
Any reason for this?
Could you describe how to get the 111 fps and 33 fps in detail?
Are you saying that with the same code, the fps can reach 111 in the docker but 33 on the host?
TO get 33 fps im just running the imagedata multistream application with one video in the docker container,
Outside the docker container we are inferencing one single image with yolov5 tensorrt model and timing how long it takes to infer that one image. That speed turns out to be 111fps.
This comparison method doesn’t have much reference value. The deepstream_imagedata-multistream app does lots other things. It transfers the buffer from GPU to CPU to draw the bbox and save images. The video decoder also cost mush time than the image decoder.
If you want to make a valid comparison, you need to use the similar pipeline with similar sources.
will deepstream-test1 be similar to what im doing in my local? because it just does inference of images
Yes. You can just change the h264parser to the plugin corresponds to your image, like pngparse, jpegparse.
Remove the osd_sink_pad_buffer_probe.
Change the sink plugin to fakesink.
