• Hardware Platform (Jetson / GPU) Tesla T4 • DeepStream Version V6.0 • JetPack Version (valid for Jetson only) • TensorRT Version 8.0 • NVIDIA GPU Driver Version (valid for GPU only) 440.118.02 • Issue Type( questions, new requirements, bugs) questions • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
i run the deepstream_python_apps/apps/deepstream-test3 with 30 input sources(H264.mp4),pgie model is yolov5m.And the FPS is only 20, is this correct ?
@gaohuizzzRtsp-muti-input is not work well in DeepStream python-app test3 describes the program cannot run normally with 30 RTSP streams, but this one describes the 30 H264 inputs files works but low FPS, so deepstream-test3 works with 30 local MP4 files (while low FPS) but not works with 30 RTSP streams, correct?
