• Hardware Platform (Jetson / GPU) Jetson Xavier NX
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.0.1-1
Hello everyone
I am trying to use yoloV3 model in deepstream_python_apps, but getting bad performance.
As Deepstream 6.0 had an issue for using Yolo, I applied the patch attached on this topic:
https://forums.developer.nvidia.com/t/deepstream-6-yolo-performance-issue/194238
After applying the patch, I got about 55 fps by running this example
/opt/nvidia/deepstream/deepstream-6.0/sources/objectDetector_Yolo/deepstream_app_config_yoloV3.txt
I also tested deepstream_app_config_yoloV3 by using two IP cameras as a input and got about 30~40 fps.
But after I used rebuilt libnvdsinfer_custom_impl_Yolo.so on python, the frame dropped to 3 fps.
I used the example code:
/opt/nvidia/deepstream/deepstream-6.0/sourcesdeepstream_python_apps/apps/deepstream-test3
and changed the files to use yoloV3 by following this step:
# cd /opt/nvidia/deepstream/deepstream-5.0/sources/python/apps/deepstream-test3/
# cp ../../../objectDetector_Yolo/config_infer_primary_yoloV3.txt dstest3_pgie_config.txt
# cp ../../../objectDetector_Yolo/yolov3.cfg ./
# cp ../../../objectDetector_Yolo/yolov3.weights ./
# mkdir nvdsinfer_custom_impl_Yolo
# cp ../../../objectDetector_Yolo/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so ./nvdsinfer_custom_impl_Yolo/
# cp ../../../objectDetector_Yolo/labels.txt ./
# python deepstream_test_3.py rtsp://127.0.0.1/video1 rtsp://127.0.0.1/video2
The result was like this:
Warning: gst-stream-error-quark: No decoder available for type 'application/x-rtp, media=(string)application, payload=(int)107, clock-rate=(int)90000, encoding-name=(string)VND.ONVIF.METADATA, a-recvonly=(string)"", clock-base=(uint)2215878722, seqnum-base=(uint)26690, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, ssrc=(uint)224613528'. (6): gsturidecodebin.c(921): unknown_type_cb (): /GstPipeline:pipeline0/GstBin:source-bin-00/GstURIDecodeBin:uri-decode-bin
Decodebin child added: nvv4l2decoder0
Decodebin child added: nvv4l2decoder1
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
In cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7f83746048 (GstCapsFeatures at 0x7eb40d3520)>
In cb_newpad
features= <Gst.CapsFeatures object at 0x7f83746048 (GstCapsFeatures at 0x7ea0075f20)>
**********************FPS*****************************************
Fps of stream 1 is 3.2
Fps of stream 0 is 3.2
Fps of stream 1 is 3.0
Fps of stream 0 is 3.0
Please help me to fix it.
Thank you so much!
