• Hardware Platform (Jetson / GPU) Tesla T4 • DeepStream Version 6.0 • JetPack Version (valid for Jetson only) • TensorRT Version 8.2 • NVIDIA GPU Driver Version (valid for GPU only) 440.118.02 • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
when i run the deepstream_python_app/apps/deepstream_test_3 with 30 rtsp inputs,the program is work unnormal
0:02:05.129206749 30244 0x7f4dec01c760 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder6:pool:src Driver should never set v4l2_buffer.field to ANY
Hello @gaohuizzz ,
Can you confirm that the abnormal only happens when there are 30 RTSP streams as input? Does it works when there is only 1 RTSP stream?
