DeepStream Inference on Large Image by Splitting into Smaller Parts
• DeepStream Version
• TensorRT Version
Hi, NVs,
"I need to detect objects in a high-resolution image or video using DeepStream. I want to split the original image into smaller patch images (for example, 8 patch images per full image) and use nvinfer to obtain bounding boxes. Afterward, I aim to combine the results from the 8 patches into one. How can I achieve this?
Is this something like SAHI?
  1. The partition should have some overlap in case some objects may cross the partition parts.
  2. The nvpreprocess plugin can be used to customize the partition parts tensor generation, you can set ROIs as your partition parts.
  3. The postprocessing should be customized to handle the bboxes clusterring after the coordinates be converted back to the original image.
We do not have such sample yet.
