• Hardware Platform (Jetson / GPU) : Jetson
• DeepStream Version : DS6.2
• JetPack Version (valid for Jetson only) : JP5.1.2
• Issue Type( questions, new requirements, bugs) : Question
I want to apply some cuda kenel based image processing that is transforming the input buffer and pushing to the downstream. (for example remapping the input buffer to the other shape of the image and push it to the output buffer)
but I’m struggling how to use NvBufSurface to be processed, with the code below I gets this error
terminate called after throwing an instance of 'cv::Exception'
what(): OpenCV(4.5.4) /opt/nvidia/deepstream/deepstream-6.2/opencv_contrib-4.5.4/modules/cudafilters/src/cuda/row_filter.hpp:172: error: (-217:Gpu API call) an illegal memory access was encountered in function 'caller'
Q. I attached the code below, could you help me how to implement what I intended to do?
- I wanted to use NV12 input/ouput, however I started with RGBA format.
... ! nvvideoconvert ! 'video/x-raw(memory:NVMM), format=RGBA, width=3840, height=2160' ! nvdsvideotemplate customlib-name="./customlib_impl/libcustom_videoimpl.so" customlib-props="scale-factor:2.0" ! ...
- I’m modifiying
SampleAlgorithm::ProcessBuffer(GstBuffer *inbuf)
in the filegst-nvdsvideotemplate/customlib_impl/customlib_impl.cpp
// in ProcessBuffer
// Push buffer to process thread for further processing
PacketInfo packetInfo;
packetInfo.inbuf = inbuf;
packetInfo.frame_num = m_frameNum;
// Add custom preprocessing logic if required, here
// Pass the buffer to output_loop for further processing and pusing to next component
// Currently its just dumping few decoded video frames
/////////// START /////////////
static bool create_filter = true;
static cv::Ptr<cv::cuda::Filter> filter;
NvBufSurfaceMap(in_surf, 0, 0, NVBUF_MAP_READ_WRITE);
cuCtxSynchronize();
if (create_filter)
filter = cv::cuda::createSobelFilter(CV_8UC4, CV_8UC4, 1, 0, 3, 1, cv::BORDER_DEFAULT);
// filter = cv::cuda::createGaussianFilter(CV_8UC4, CV_8UC4, cv::Size(31,31), 0, 0, cv::BORDER_DEFAULT);
create_filter = false;
cv::cuda::GpuMat test = cv::cuda::GpuMat(in_surf->surfaceList[0].height, in_surf->surfaceList[0].width, CV_8UC4, (unsigned char *)in_surf->surfaceList[0].dataPtr);
// this is an example
// I want to use custom cuda kernel once this test works.
filter->apply(test, test);
cuCtxSynchronize();
NvBufSurfaceUnMap(in_surf, 0, 0);
////////// END //////////////
// Enable for dumping the input frame, for debugging purpose
if (0)
DumpNvBufSurface(in_surf, batch_meta);
m_processLock.lock();
m_processQ.push(packetInfo);
m_processCV.notify_all();
m_processLock.unlock();
