• Hardware Platform (Jetson / GPU) Jetson AGX Orin • DeepStream Version 6.2 • JetPack Version (valid for Jetson only) 5.1 • TensorRT Version 8.5.2.2 • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hi, I got an error while converting the onnx model into an engine file.
The onnx file is a segmentation model with 3 outputs and one of them is the segmentation mask while the others are negligible.
There are some issues with your model reshape. Could you describe how your model was generated? If convenient, you can also attach your ONNX model.
